Best cams - Mustang Evolution
Old 07-15-2013, 07:53 PM   #1
Luna1994's Avatar
Region: Utah
Best cams
I'm looking for cams best for power If I get some I want the best ones. What do I need to run them and were to find all the parts. Iv already got cold air intake and full cat back. Underdrive pulleys and tuner. I want the most gains with the cams. And how hard is install I'm pretty mechanically inclined
Luna1994 is offline   Reply With Quote
Old 07-15-2013, 07:59 PM   #2
Kcstunna82's Avatar
Detroit rockers
Kcstunna82 is offline   Reply With Quote
Old 07-15-2013, 11:35 PM   #3
Luna1994's Avatar
Region: Utah
Anyone else?
Old 07-16-2013, 03:35 AM   #4
05stangGT's Avatar
FRPP hot rod cams have good power gains and an awesome sound with them as we'll ( that's what I'm running). But if you are looking for the best power a can can give you the Detroit rockers is the way to go.
---------- Post added at 03:35 AM ---------- Previous post was at 03:34 AM ----------
Cam*
05stangGT is offline   Reply With Quote
Old 07-16-2013, 05:28 AM   #5
610swolf's Avatar
detroit rocks definately
610swolf is offline   Reply With Quote
Old 07-16-2013, 12:22 PM   #6
Luna1994's Avatar
Region: Utah
Why do I need to go with them? How hard is install
Old 07-16-2013, 12:31 PM   #7
Edd204's Avatar
Install is pretty easy as long as you follow the directions carefully And take your time. I did the frpp cams with a buddy and it went smooth. Did need a 3v spring compressor and a timing wedge which costed a couple all toghter
Edd204 is offline   Reply With Quote
Old 07-16-2013, 12:36 PM   #8
Luna1994's Avatar
Region: Utah
What about the stage 2 or the stage 3 cams?
---------- Post added at 12:36 PM ---------- Previous post was at 12:36 PM ----------
I think vsr if I remember right
Old 07-16-2013, 12:39 PM   #9
Stanglover1966's Avatar
Stages vary with manufacturer. Usually stage 3 is a tier 1 type of product for most companies, maybe tier 2. As a DD, don't go with a stage 3. Those cams are usually meant for the track and are not worth the money in a DD. as for what would be recommended to use with the cam: get a set of heads and an intake manifold to MATCH the cam specs. Those 2 parts work with the cam and be sure you match them or you'll lose power.
Stanglover1966 is offline   Reply With Quote
Old 07-16-2013, 01:42 PM   #10
Luna1994's Avatar
Region: Utah
Why is stage 3 bad for a dd?
Old 07-16-2013, 08:34 PM   #11
Like I said before, they are meant for track (most are anyways.) Mpgs might show a difference and you might get a complaint call from your neighbors. It's not worth the money for a DD. it gives you a lot of power you don't need.
Old 07-17-2013, 01:24 AM   #12
Maraqt101's Avatar
I have the ford racing hot rod performance camshafts- make sure u order the cam phaser bolt with it!! Once you pull it you can't use it again and you will be stuck without a car
Maraqt101 is offline   Reply With Quote
07:48 PM
