Omg help right now!! Please - Mustang Evolution
Old 07-25-2013, 09:21 PM   #1
Graham1992's Avatar
I had a miss, so I stopped and checked the code and started to go home, now it has THE CLICKING NOISE OF DEATH! Knocks on the passenger bank get faster with the revs! Help me. Please.
Graham1992 is offline   Reply With Quote
Old 07-25-2013, 09:35 PM   #2
Graham1992's Avatar
Nobody?
Old 07-25-2013, 09:38 PM   #3
I don't know much about mechanical issues... I'll try to get someone who does.
Old 07-25-2013, 09:39 PM   #4
Graham1992's Avatar
Okay
Old 07-25-2013, 09:49 PM   #5
ForsakenProto's Avatar
Whats the code? Ill pull it up
ForsakenProto is offline   Reply With Quote
Old 07-25-2013, 09:58 PM   #6
Graham1992's Avatar
It just says misfire on 3. But it's a valve knock.. Im almost positive!
Old 07-25-2013, 10:04 PM   #7
So no actual code, like a p0174 or something? How mechanically inclined are you? Theres some steps I'd like you to take right off the bat, does it knock immediately at start up after cooling down, or is it there from start up too? also, lower on the block or towards the top? It could very well be a valve not operating, but if thats the case you'd then have to figure out which one is not performing correctly. Easiest way to do that is with a compression test
Old 07-25-2013, 10:06 PM   #8
Graham1992's Avatar
It's. at the top and on the passenger bank. All the time. No matter what.
Old 07-25-2013, 10:12 PM   #9
Are you mechanically inclined enough to remove the valve cover and check the valve train?
Old 07-25-2013, 10:18 PM   #10
Graham1992's Avatar
As soon as I get home lol I think I can anyway
Old 07-25-2013, 10:23 PM   #11
Good, let me know if theres anything blatantly obvious out of the ordinary. However, before this id definitely recommend making sure that its not spark or fuel related, you say the knocking didnt start til after it was misfiring a bit? thats a pretty good indication that it may not be valve train related.
It may be tomorrow before i reply back, one because its 12 now and i have work at 8, and two, because im waiting for a password reset for my ford technician account, which should be in tomorrow sometime
Old 07-25-2013, 10:28 PM   #12
Graham1992's Avatar
Okay sounds good. And yeah it did act up a bit before it done this but this is not a spark knock.. I'm almost sure it's in the valve cover.
Old 07-25-2013, 10:31 PM   #13
It's not me, it's you.
primer2tone's Avatar
I'd pull the spark plug first. Inspect it, then do a compression test. Does your mustang have an oil pressure gauge in the cluster? You need to be certain you've got adequate oil pressure.
Old 07-25-2013, 10:54 PM   #14
Graham1992's Avatar
Oil pressure just fine
Old 07-25-2013, 11:58 PM   #15
Graham1992's Avatar
So I took the valve cover off and I found a valve that had some metal peices on it.. That looks like my issue.
Old 07-26-2013, 06:11 AM   #16
Pics?
Old 07-26-2013, 07:49 AM   #17
Graham1992's Avatar
Pics?
Happy? Lol
ID:	120588   Click image for larger version
ID:	120590   Click image for larger version
Old 07-26-2013, 08:36 AM   #18
That piece of loose metal, is it half moon shaped with grooves in it?
Old 07-26-2013, 10:42 AM   #19
Graham1992's Avatar
Yes sir. Think you may know?
Old 07-26-2013, 11:12 AM   #20
Take a picture of that piece just so I can make sure its what I think it is. If it is what i think, then you're gonna have some fun motor work ahead
Old 07-26-2013, 11:33 AM   #21
Graham1992's Avatar
Oh man... I lost it in the valve train when I tried to get it out. Go ahead and lay it on me
Old 07-26-2013, 12:01 PM   #22
Most likely it's a keeper that came loose. Usually means the valve came loose too which could damage the valve and piston
Old 07-26-2013, 12:41 PM   #23
Graham1992's Avatar
Found no metal at all in my oil.
Old 07-26-2013, 01:05 PM   #24
Boomdizzle's Avatar
Yikes. At least it seems you may know what it is, but that won't be an easy fix. I have a feeling the cams and everything are going to have to come off.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 07-26-2013, 01:26 PM   #25
There could be some in the filter. But either way that head needs to come off for inspection
Old 07-26-2013, 01:36 PM   #26
Happy? Lol
Why would I be happy? It looks like your car is gonna be down for a little while. Get the cam off and take some more pics. I wanna see the effected area. This is very interesting.
Old 07-26-2013, 01:57 PM   #27
I've seen a case where a keeper has come off, wiggled down and made a nice gash in the valve itself
Old 07-26-2013, 02:05 PM   #28
Davo_281GT's Avatar
Yeesh! Not cool man......I'll say a little prayer for your baby...and your checkbook.
"A mans reach should exceed his grasp."
Davo_281GT is offline   Reply With Quote
Old 07-26-2013, 02:22 PM   #29
Damn, yeah my crx had a rocker adjuster break off and get wedged between the valve seal and valve stem. It ****ed **** up good! Lol
Old 07-26-2013, 04:57 PM   #30
Graham1992's Avatar
So far I've had two local mechanic friends look at it and now a third one is pulling in the driveway. Hopefully we can fully diagnose it before the night. But idk.. Looks like I may have to pull the motor and I don't have any close friends with a lift they can go without for a week or so. Hopefully it's in the valve train so I won't have to. But all in all, the worst that can happen, is I get a new rotating assembly.. I just won't be going nitrous for a while longer.
Old 07-26-2013, 04:59 PM   #31
What has been their general consensus on it?
Old 07-26-2013, 06:00 PM   #32
Graham1992's Avatar
I'm gonna to pull it... There's either something in there that has come loose, or something has broke. I'm still really confused as to why there were peices of something in the valve train.. That worrys me. But like I said, if worse comes to worse, ill be getting a whole rotating assembly a little early..
10:21 PM
