P0456 evap leak - Mustang Evolution
Old 07-28-2013, 05:36 PM   #1
Mustangman92's Avatar
P0456 evap leak
Alright guys, I'm a bit puzzled by this one. My dad has a 2005 mustang gt vert and the check engine light keeps coming on for a p0456 small evap leak. We have replaced the gas cap and the fuel pump, but neither has fixed the problem. Ford dealers nor my mechanic friend have any other clue what the problem might be. Do you guys have any suggestions to find/fix the problem. Thanks guys.
Mustangman92 is offline   Reply With Quote
Old 07-29-2013, 12:10 AM   #2
Scotts197gt's Avatar
If its an evap leak then it could be a vacuum line
Scotts197gt is offline   Reply With Quote
Old 07-29-2013, 06:35 AM   #3
montreal's Avatar
Hi Mustangman 92. There must be someting in here for you.
montreal is offline   Reply With Quote
Old 07-29-2013, 12:51 PM   #4
Is there anyway to make the PCM test for evap leaks? And how would you check all the lines or what would be the fasted way?
Old 07-29-2013, 02:22 PM   #5
montreal's Avatar
Only way to check is at your Ford Stealer. With there Diagnostic tool. They have a smoke machine that they plug in your EVAP system and find the leak.Only thing you can check is hoses and connections. Check Purge valve make sure it is close. It is near right front inner fender well.
Old 07-29-2013, 03:15 PM   #6
We actually took it to them and they told us ford had a bulletin out on that code and the remedy for it was to swap out the fuel pump. They charged a 100 diagnostic fee for that as well
Old 07-29-2013, 03:54 PM   #7
montreal's Avatar
So your back to square one. Dint you change the fuel pump before.
Old 07-29-2013, 08:55 PM   #8
Ya but the ford dealership never did the smoke test
Old 07-29-2013, 09:20 PM   #9
montreal's Avatar
Maybe next thing they will do if fuel pump ok. The only way to find a leake. There goes a other big one saddely . Good Luke keep me posted.
Old 08-19-2013, 02:14 AM   #10
error code table: Diagnostic Trouble Code (DTC) Table Free Download
hellozaizai is offline   Reply With Quote
Old 04-21-2017, 08:15 AM   #11
RedAtlGT's Avatar
my 06 just threw me this code yesterday. any updates on this? im going to reset it for now
RedAtlGT is offline   Reply With Quote
10:54 PM
