Rattling - Mustang Evolution
Old 08-07-2013, 04:08 PM   #1
Jeremy.baker's Avatar
Region: Nebraska
Rattling
I have noticed while i am driving that there is a rattling coming from my exhaust. It isn't constant though, it comes and goes. I have gone back there and made sure everything is tight and it still rattles. Any ideas?
Jeremy.baker is offline   Reply With Quote
Old 08-07-2013, 06:05 PM   #2
Wolverine0587's Avatar
Make sure it's not hitting where the spare tire sits.
Wolverine0587 is offline   Reply With Quote
Old 08-07-2013, 06:13 PM   #3
Region: Nebraska
It isn't
Old 08-07-2013, 08:14 PM   #4
Langer1099's Avatar
@JeremyBaker; I had the same issue with my exhaust after I installed it. I'm not saying this is the exact issue, but this is my guess...
Check the hangers that your actual exhaust is held up with. When your car heats up those hangers move 0.5 to 1 inch. When those hangers move they tend to rattle against the hanger mounts. (which are black mounts bolted to the underside of the car) What I did was take some 3/8th sized rubbing tubing and wrapped them around the hangers that hold up your exhaust pipes/tips (so when the heat expanded them, they would still hit against the hanger, but the rubber hose would be hitting it, therefore making no metal on metal rattle). I cut them down the side and then proceeded to zip tie them tight. I haven't had a rattle since.
I hope this helps....This is just based off of the rattle I had on my car.
2009 Mustang GT Premium; FRRP 4.10 Gears, J&M Lower Control Arms, BBK Long Tube Headers, BBK Catted X Pipe, Pypes M80 Mid Mufflers, Pypes Pype Bomb Axle Back, JLT Series 3 Cold Air Intake, Bama 93 Octane Race Tune, Black Decklid Panel, Weathertech Mats, SVE Shifter and Shorty Antenna.
Langer1099 is offline   Reply With Quote
Old 08-07-2013, 08:30 PM   #5
Region: Nebraska
Thanks for the help, i am going to try that tomorrow morning and see if it helps.
Old 08-07-2013, 08:55 PM   #6
Langer1099's Avatar
No problem. I can just about promise that is the problem. I searched and searched for my rattle and really the hangers are the only thing that can possibly make them rattle.
Old 08-07-2013, 09:29 PM   #7
dr.gsxr1000nos's Avatar
One of those things you have to climb under and investigate.....
dr.gsxr1000nos is offline   Reply With Quote
Old 08-08-2013, 12:23 PM   #8
Region: Nebraska
Okay so i did the thing with the rubber hose and it stopped the rattle on my passenger side. Then about 15 minutes into my test drive, the driver's side started rattling! Any other ideas?
Old 08-08-2013, 12:44 PM   #9
Site Sponsor
Sponsor
AMWill's Avatar
Jeremy.baker,
Are the rubber mounts for the hangers badly aged? Do they seem to sag or stretch too much? If so, maybe a set will do the trick. It sounds like you have way too much movement in your exhaust to me..
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 08-08-2013, 01:11 PM   #10
Region: Nebraska
They do seem to be too bad but i don't know what they would look like new. How much would a new set be?
---------- Post added at 02:11 PM ---------- Previous post was at 02:08 PM ----------
Don't*
Old 08-08-2013, 02:04 PM   #11
Region: Nebraska
Don't*
Old 08-08-2013, 07:20 PM   #12
Langer1099's Avatar
I wrapped all of my exhaust hangers in rubber coating. I would say 5 inch pieces of 3/8ths thick rubber tubing. A total of 4 hangers are wrapped. 2 for each side. Wrap them all!!!
Old 08-09-2013, 11:30 AM   #13
Site Sponsor
Sponsor
AMWill's Avatar
Don't*
Jeremy.baker,
We do have the SR Performance stainless steel exhaust hangers available. These are replacements for the very rear hanger(s), which sounds like the ones that are causing you problems.
Hopefully this does the trick!
Shane
Old 08-09-2013, 11:52 AM   #14
Region: Nebraska
Because only two hangers come with those, do i only need to replace one on each side, or should i order two sets and replace all four?
Old 08-12-2013, 12:50 PM   #15
Site Sponsor
Sponsor
AMWill's Avatar
These are just the rear hangers, closest to the end of the car. I believe the next set of exhaust hangers are different shaped, but for some reason it's slimming my memory. I have 94-04 Mustangs stuck on my mind..
Shane
Old 08-12-2013, 01:34 PM   #16
Region: Nebraska
Okay, thanks for the help
07:33 PM
