Difference between the 2v and 3v 4.6 engines - Mustang Evolution
Old 08-11-2013, 12:26 AM   #1
tony92's Avatar
Hey just bored and I was just wondering what the differenve was between the 2v and 3v v8 engines in the mustangs.
Which one is faster? Better?
Which one makes better exhaust sound if there is a difference and also what about the 4vs??
Thanks im just curious
tony92 is offline   Reply With Quote
Old 08-11-2013, 01:26 AM   #2
C_Dailey95's Avatar
I'm pretty sure the higher the number the more power the engine makes. So an 8v engine makes more power than a 4v engine and so on, Correct me if I'm wrong. There's more to it but I can't remember, I read it on another thread haha
C_Dailey95 is offline   Reply With Quote
Old 08-11-2013, 01:28 AM   #3
tony92's Avatar
Well I didnt even know that haha I honestly thought my 06 gt had the same 4.6 as my buddys 03 gt but he said they were different so I had to ask
Old 08-11-2013, 01:31 AM   #4
MidnightBlueGT's Avatar
8v?
Old 08-11-2013, 01:37 AM   #5
C_Dailey95's Avatar
Originally Posted by MidnightBlueGT View Post
8v?
I don't even know. He had that listed so I used it for an example haha
Old 08-11-2013, 02:06 AM   #6
wc3john's Avatar
More valves generally ( again generally ) mean better volumetric efficiency ...
The better the VE, the more powerful and efficient the engine is. Hence why the new coyote makes so much power and yet still gets good gas mileage.
---------- Post added at 03:06 AM ---------- Previous post was at 03:04 AM ----------
3v's are generally faster in stock, factory form.
Sound is up to the owner...
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 08-11-2013, 06:31 AM   #7
bigmac3's Avatar
...what the difference was between the 2v and 3v ...
The "v" refers to valves per cylinder. Thus a 3-valve engine would allow for better breathing and fuel mixture flow. which results in more power. In a 2v there are 1 intake and 1 exhaust valve. The 3v uses 2 intakes and 1 exhaust valve. The 4v uses 2 intakes and 2 exhaust valves. The 1994-2004 (with exception of Cobras and Mach Is) had the 4.6L 2v engines while the 2005-2010 had the 4.6L 3v engines. Starting in 2011 the engines went to 5.0L 4v. Hope that helps.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 08-11-2013, 09:28 AM   #8
tony92's Avatar
That explains it all haha thanks
Old 08-11-2013, 11:29 AM   #9
1slosix's Avatar
This is why when I buy an ae86 I'm swapping in a 5v blacktop motor lol
carving corners like a boss
Old 08-11-2013, 11:38 AM   #10
1lowGT's Avatar
This started out horrible
Old 08-13-2013, 08:26 AM   #11
Send a message via AIM to Destination S19
Besides the fact that one is a 2V and the other is a 3V, there isn't too much differnce. The 3V has an extra intake valve and a better intake manifold for increased flow which accounts for the power increase over the 2V. The 2V engines were cast iron and the 3V engines are all aluminum shaving about 70lbs off of the front of the car.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 08-13-2013, 10:06 AM   #12
This. And except for the motor mounts, the 2v and 3v blocks are the same.
2006 GT Redfire 5 Spd Manual. Saleen S/C. Custom Diablo tune by Adam @ ST Motorsports, San Bernardino, CA.
Redfire281 is offline   Reply With Quote
04:17 AM
