No throttle reaponse help :( - Mustang Evolution
Old 08-12-2013, 11:56 PM   #1
MVP u eNVy ME's Avatar
I just installed an Airraid CAI with a tune and started the car and it was OK for like 30 seconds and then the car randomly turned off. Turned car back on and there was 0 throttle response. Ran a diagnostic with my tuner and 2 problems came up both in regards to a throttle failure. Put stock tune back on and stock intake and same thing happened. So the stang is currently immobile.
Help please
MVP u eNVy ME is offline   Reply With Quote
Old 08-13-2013, 12:03 AM   #2
Aggiesrok's Avatar
Help please
What were the codes?
Old 08-13-2013, 12:05 AM   #3
MidnightBlueGT's Avatar
+1. You sure thats what it was?? Seems odd that you just tuned it and returned to stock and still had the issue.
Old 08-13-2013, 12:09 AM   #4
Yes very weird. I'm not too sure of the failure numbers right now. Left the car with a buddy, I gave up after a while. Been laying here and it's driving me crazy, hopefully don't have to replace anything. All I know is that there were 2 failures, both starting with 2 and involving the throttle response
Old 08-13-2013, 12:38 AM   #5
Terminator's Avatar
Did you make sure all wires were plugged in & no loose parts
Terminator is offline   Reply With Quote
Old 08-13-2013, 12:45 AM   #6
1shotkllz's Avatar
Post up some pics if possible. Doesnt sound like something was hooked back properly. I've never heard of anything like this
1shotkllz is offline   Reply With Quote
Old 08-13-2013, 06:18 AM   #7
Error codes P2104 and P2111
Old 08-13-2013, 07:15 AM   #8
I looked it up saw something about the throttle position sensor.couldnt read to much since I have to back to work its something with a sensor I'm guessing but again don't quote me in it though.
Torchred2010gt is offline   Reply With Quote
Old 08-13-2013, 07:46 AM   #9
tony92's Avatar
I had the same thing happen to me but it was when I was installung my new throttle body
Itwas because I didnt get the right voltage
tony92 is offline   Reply With Quote
Old 08-13-2013, 10:32 AM   #10
maldog's Avatar
Region: Nevada
Disconnect your battery for 30 minutes then reconnect and try starting it.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-13-2013, 11:13 AM   #11
How did you fix it?
Old 08-13-2013, 02:44 PM   #12
tony92's Avatar
How did you fix it?
Well I just put the old throttle body back and and it went back to normal. And then went and got it professionally installed. And everything is fine.
But everything that happened to you haooened to me I was really upset because there was 0 throttpe response and my car would shut off
Old 08-13-2013, 04:34 PM   #13
C_Dailey95's Avatar
I had the throttle position sensor code before too, same effects, I replaced the sensor and it's worked perfect ever since.
C_Dailey95 is offline   Reply With Quote
Old 08-13-2013, 04:47 PM   #14
Which sensor? The MAF?
Old 08-13-2013, 04:48 PM   #15
1shotkllz's Avatar
The Throttle Position Sensor. It's connected to your throttle body. You could of bumped it on the install
Old 08-13-2013, 04:50 PM   #16
How did you figure that out that you needed a new one? Is there anyway you can check?
Old 08-13-2013, 05:10 PM   #17
1shotkllz's Avatar
Have you even checked the maf sensor yet? Lol, the throttle position sensor I was having rough idle and it didn't run good. Kind of like the same symptoms of a dirty IAC
Old 08-13-2013, 05:23 PM   #18
C_Dailey95's Avatar
Yeah what he said, I can get a picture of it if you want.
Old 08-13-2013, 05:51 PM   #19
I've checked the maf sensor it's plugged in and facing the right direction. Everything is plugged in right
Old 08-13-2013, 06:07 PM   #20
alrefire's Avatar
Is it clean?
12:07 AM
