Muffler help - Mustang Evolution
Old 08-16-2013, 05:23 PM   #1
Jeremy.baker's Avatar
Region: Nebraska
Muffler help
I installed some pypes violators and when i put them in they both hung a little low and one was off center, any suggestions on how to fix?
ID:	124160   Click image for larger version
Jeremy.baker is offline   Reply With Quote
Old 08-16-2013, 05:45 PM   #2
NewMtang's Avatar
Just push on it to the right. Mine were a little off and have not moved back.
Old 08-16-2013, 05:51 PM   #3
Region: Nebraska
How much did you have to push? I have tried that some
Old 08-16-2013, 07:11 PM   #4
NewMtang's Avatar
Till it moved. Wasn't a whole lot of pushing and it would take one hell of a bump on the road to move it.
Old 08-16-2013, 08:46 PM   #5
Wolverine0587's Avatar
Mine were outta line too when first installed. He's right about just and pushing them.
Wolverine0587 is offline   Reply With Quote
Old 08-16-2013, 08:52 PM   #6
Region: Nebraska
I tried pushing it but it just went back to where it was originally
Old 08-16-2013, 08:53 PM   #7
stemar's Avatar
Loosen the hanger brackets that are bolted to the car also losen the muffler clamp push the muffler to the possition that you want it then tighten the bracket bolts then retighten the muffler clamp
Pypes shorties, BBK catted X, Flowmaster Pro's, K&N CAI, FRPP- P springs, Steeda UCA, J&M Panhard bar, Hurst Comp plus, FR500 Wheels W/NITTO's , SCT SF3 W/BAMA 93 Race tune, Pioneer TS-D6802R speakers, chin spoiler, Eleanor style grill, GT500 rear spoiler
stemar is offline   Reply With Quote
Old 08-16-2013, 10:03 PM   #8
corey herron's Avatar
i had to bend my hangers a lil bit and then rotate the muffler and tighten it down
New found love... the 06 GT
corey herron is offline   Reply With Quote
Old 08-17-2013, 08:06 PM   #9
Region: Hawaii
Loosen everything up and then place the muffler and tip where you want it. Then tighten everything back up, you might need to bend the hangers a tiny bit.
Pat12p is offline   Reply With Quote
Old 08-18-2013, 01:53 PM   #10
Torchredfrankie's Avatar
Had the same problem with my SLP I need brackets the stock ones can't be used ): any idea were I can buy some?
Torchredfrankie is offline   Reply With Quote
Old 08-18-2013, 05:12 PM   #11
Hello?????
Old 08-18-2013, 05:32 PM   #12
American Muscle has some, summit, maybe even late model restoration.
Old 08-18-2013, 06:04 PM   #13
Region: Nebraska
I got 2 from am and just replaced the rear ones
Old 08-18-2013, 06:13 PM   #14
I have to replace the two front ones
Old 08-18-2013, 08:16 PM   #15
Region: Nebraska
I think the ones on am work for both the front and rear
Old 08-21-2013, 08:48 PM   #16
maverick214's Avatar
Loosen the mid pipe, then have someone move the muffler into place then tighten mid pipe.
maverick214 is offline   Reply With Quote
Old 08-22-2013, 08:46 AM   #17
Send a message via AIM to Destination S19
Like maverick said, loosen the over axle pipe from the mid pipe and wiggle/move things around until they get into place.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 08-22-2013, 08:51 AM   #18
Region: Nebraska
Okay thanks for the help
03:05 PM
