Play and shaking at the drive train? - Mustang Evolution
Old 08-19-2013, 06:26 PM   #1
GT330's Avatar
I have an 06 GT
As I'm pulling over speed bumps at an angle or going over the bump in front of my driveway, I can hear and feel something in the back of the car shaking and lurching side to side. Happens at all speeds.
Also as I'm shifting at low speeds usually 1-3rd gear, it makes the same sound if I let the clutch out even a little too fast, and the car lurches back and forth.
Is this a broken engine mount? Tranny mount? A shot damper? I'm stumped.
06 GT, o/r x-pipe, magnaflow mufflers, airaid short ram.
GT330 is offline   Reply With Quote
Old 08-19-2013, 06:57 PM   #2
Aggiesrok's Avatar
Have you checked the panhard bar to see if its broke loose or lost bolts?
Old 08-19-2013, 07:06 PM   #3
GT330's Avatar
Appears to be tight. Ill get a better look in the morning but assume that's up to spec for bow
Old 08-19-2013, 07:20 PM   #4
Aggiesrok's Avatar
You might check welds and the LCA,s.
Old 08-19-2013, 07:39 PM   #5
GT330's Avatar
The lca's are aftermarket. J&m is the company that makes them I believe. Gonna take a look in the morning.
Old 08-30-2013, 02:58 PM   #6
WhiteTiger13's Avatar
I have an 06 GT
I have the same exact thing happening with my 2013 CS. I have the Ford warranty on it and was gonna have them look at it at my next oil change
WhiteTiger13 is offline   Reply With Quote
Old 08-31-2013, 01:07 PM   #7
GT330's Avatar
Definitely keep me posted. I've been wondering for months!!
Old 10-09-2013, 10:38 AM   #8
Took it in and they said they couldn't reproduce the sounds or feeling but that the transmission is "known to ride rough"
Old 10-09-2013, 11:10 AM   #9
mystang50's Avatar
typical
Old 10-09-2013, 11:55 AM   #10
GT330's Avatar
Known to ride rough huh. Alrighty then! Well thanks for keeping me posted. I've gotten better with it but at low speed its just hard to avoid.
05:42 PM
