How do yall jack up your stangs? - Mustang Evolution
Old 08-24-2013, 06:09 PM   #1
Coleton's Avatar
Title!
Coleton is offline   Reply With Quote
Old 08-24-2013, 07:49 PM   #2
Used to start with the cross member in the front, but now i don't have enough clearance (lowered it) for that so i do one side right behind the front wheel, and then the other... Then for the rear i do it from the diff. Some people say don't do it from the diff, others say you can. I've never heard of any cases of anything happening so i do it from there.
Old 08-24-2013, 07:52 PM   #3
Coleton's Avatar
Is the emergency jack good enough to get jack stands under? My floor jack just broke and rather buy parts lol
Old 08-24-2013, 07:59 PM   #4
It should be, just make sure you do the jack points on the sides. I have a feeling it won't be able to lift the rear from the diff.
Old 08-24-2013, 08:00 PM   #5
Coleton's Avatar
Kk ty just need it to do lowering kit and paint calipers
Old 08-24-2013, 11:06 PM   #6
610swolf's Avatar
I've been using my scissor jack ( the one that came with the mustang) since my floor jack crapped out on me. it'll work just fine. it'll just take longer to get the car in the air haha. I don't believe you can lift from the diff with it either.
610swolf is offline   Reply With Quote
Old 08-26-2013, 05:58 AM   #7
BeachMonkey100's Avatar
I lowered my car too and I have plenty of floor jacks (3) but didn't have low spec jack, so I just put the car in the shop, use 12x12 3/4" MDF that I had left over from box building and drive on it, and wallah! perfect clearance!
2006 Mustang GT Premium Satin Silver Metallic | 5 Speed Manual | Hurst Short Shifter | K&N CAI | JSR Strut Brace, FLCA Brace, Rear Shock Tower Brace | Flowmaster Axle Backs | Ford K Springs | JM Trackbar | 93 Bama Performance Tune
BeachMonkey100 is offline   Reply With Quote
Old 11-04-2013, 08:26 PM   #8
Blown05's Avatar
low profile jack from harbor frieght!! 79$ and fits under it just fine even if i lowered my car alot
Blown05 is offline   Reply With Quote
Old 11-05-2013, 03:06 PM   #9
Terminator's Avatar
Bought one but for my car its not low enough i need 2 jacks to get it started
Terminator is offline   Reply With Quote
Old 11-06-2013, 09:06 AM   #10
Send a message via AIM to Destination S19
Start off with my race ramps and ramp extensions. (Using a low profile floor jack)
and then I jack using the bracing under the engine and place jacks under it.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 11-08-2013, 07:57 AM   #11
1lowGT's Avatar
Drive front wheels on 2x4 get a jack under it jack it up do what need to do then sane for the rear
Old 11-08-2013, 05:46 PM   #12
cmegnin1's Avatar
I use the jack points under the rocker panels on the frame as notes in the owner's manual with a jack and jack stands.
04:20 AM
