Lowering car - Mustang Evolution
Old 08-29-2013, 08:18 PM   #1
Coleton's Avatar
Lowering car
I got eibach sport line lowering springs do I need anything else? New strut mounts?
Coleton is offline   Reply With Quote
Old 08-29-2013, 08:21 PM   #2
Langer1099's Avatar
Probably a new panhard bar and some camber bolts. Shocks and struts are always a good idea too (from what I've heard).
2009 Mustang GT Premium; FRRP 4.10 Gears, J&M Lower Control Arms, BBK Long Tube Headers, BBK Catted X Pipe, Pypes M80 Mid Mufflers, Pypes Pype Bomb Axle Back, JLT Series 3 Cold Air Intake, Bama 93 Octane Race Tune, Black Decklid Panel, Weathertech Mats, SVE Shifter and Shorty Antenna.
Langer1099 is offline   Reply With Quote
Old 08-29-2013, 08:22 PM   #3
Coleton's Avatar
Damn thought I could get away with 240 guess its gotta wait
Old 08-29-2013, 08:31 PM   #4
Coleton's Avatar
Has anyone done this and what did they buy? I'm using the eibach sportlines
Old 08-29-2013, 09:56 PM   #5
tony92's Avatar
I bought the sr performance lowering springs. They lowered my car pretty good. Love them.
tony92 is offline   Reply With Quote
Old 08-29-2013, 10:26 PM   #6
RedSleeper's Avatar
Important to get chamber plates dude. The stock will suck with modified lowering springs.
Bumpy ride, noise, some say made rattles.
Chamber plates and lowering springs will work fine for a starter on suspension.
Loving the days when you travel down to Mexico to push your car to the limits!
RedSleeper is offline   Reply With Quote
Old 08-29-2013, 10:27 PM   #7
tony92's Avatar
I didnt get them and my ride is still smooth
Old 08-29-2013, 10:31 PM   #8
RedSleeper's Avatar
Oh. I guess depends on how many miles does play a role in this.
I got chamber plates to be safe. Lol
Old 08-29-2013, 10:32 PM   #9
tony92's Avatar
Yea maybe haha I got 40000 on mine maybe ill need em down the road
Old 08-29-2013, 10:34 PM   #10
RedSleeper's Avatar
Yeah maybe.
I like to play with my car safe. Don't like to get a item then end up waiting for another item that I should've got in first place. Lol
Old 08-29-2013, 10:35 PM   #11
tony92's Avatar
Yeah maybe.
Yea u right id get em if I were u...whoever posted this thread
Old 08-30-2013, 02:28 AM   #12
C_Dailey95's Avatar
I have springs camber bolts and panhandler bar and mine good. I may need to replace shock/struts in a while but it's fine.
I was told
More than 1.5" drop - camber plates
Less than 1.5" drop - camber bolts
C_Dailey95 is offline   Reply With Quote
Old 08-30-2013, 06:08 AM   #13
corey herron's Avatar
I dropped my 1.5 and it sits fine no noises but just a little wear on the inside of my front tires
New found love... the 06 GT
corey herron is offline   Reply With Quote
Old 08-30-2013, 06:38 AM   #14
610swolf's Avatar
i added gt500 strut mounts, no camber bolts and already had the panhard bar on sr spring. i'll need to replace the shocks and struts soon but i knew that before I did the drop. so far so good.
610swolf is offline   Reply With Quote
Old 08-30-2013, 08:26 AM   #15
Coleton's Avatar
Stock struts and shocks? Heard gt500 cc's won't work on stock shocks?
Old 08-30-2013, 10:11 AM   #16
610swolf's Avatar
GT500 Strut mounts will fit stockers or aftermarket on 2005 through 2010 mustangs. 2011 and 2012 you have to have the ford racing shocks struts otherwise they won't work..
Old 08-30-2013, 10:14 AM   #17
Coleton's Avatar
Sweet ok thanks man that saves me some cash right there, is it easy to install my self?
---------- Post added at 10:14 AM ---------- Previous post was at 10:12 AM ----------
Also will a strut brace work with them?
Old 08-30-2013, 10:20 AM   #18
BeachMonkey100's Avatar
yeah if you have the lowering springs already on there isn't a need for a spring compressor pretty much on and off. and yes you can use the strut tower brace, same 4 studs coming up through the top, just the rubber pads are a little bit beefier.
2006 Mustang GT Premium Satin Silver Metallic | 5 Speed Manual | Hurst Short Shifter | K&N CAI | JSR Strut Brace, FLCA Brace, Rear Shock Tower Brace | Flowmaster Axle Backs | Ford K Springs | JM Trackbar | 93 Bama Performance Tune
BeachMonkey100 is offline   Reply With Quote
Old 08-30-2013, 12:18 PM   #19
610swolf's Avatar
[QUOTE=Coleton;1780119]Sweet ok thanks man that saves me some cash right there, is it easy to install my self?
I'm not mechanically gifted with cars at all, your talking to the same guy that intitally gave up on changing his back breaks because the caliper got stuck haha. But it was pretty easy. the back springs were easy to get in, super simple I managed those in 30 minutes. The front took aabout two hours to unbolt both sides and get together but it's pretty straight forward. I watched motorz video on suspension work and looked at a lot of write ups the night before I did it.
Old 08-30-2013, 01:02 PM   #20
Coleton's Avatar
Awesome ya ill be good haha I don't have a spring thingy for the front springs
Old 08-30-2013, 02:15 PM   #21
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
You don't necessarily need anything else. However, there's a few things you can do that will go well together with your Springs! I installed a set of Eibach Sport lines on my 2011 GT, got it aligned and I'm good to go. You could do Struts/Shocks and caster camber plates, it just depends on how many miles are on the car. If your car has say 60+ K on it, when you put the springs on the struts/shocks may blow out shortly after. Also, if you go lower than 1.5" you'll need caster camber plates. Anything less than that, just a simple alignment will do the trick!
I would recommend throwing the Springs in, getting it aligned and see how it rides. If it's a little bouncy, just throw some Shocks/Struts down the road!
I hope this helps. Let me know if you have any questions or need some assistance, feel free to shoot me a PM!
-Dan
Old 08-30-2013, 02:36 PM   #22
GT330's Avatar
So here's what I've got:
Bilstein HD shocks and struts
H&R race springs
GT500 strut mounts
Eibach camber bolts
Will this all work out on my basically stock 06 gt?
Gonna install it all at once.
06 GT, o/r x-pipe, magnaflow mufflers, airaid short ram.
GT330 is offline   Reply With Quote
Old 08-30-2013, 02:37 PM   #23
Coleton's Avatar
H&R race springs
GT500 strut mounts
Eibach camber bolts
Yup,
Old 08-31-2013, 10:41 AM   #24
hubbs's Avatar
Post before and after pics please
hubbs is offline   Reply With Quote
Old 08-31-2013, 12:36 PM   #25
Coleton's Avatar
Will do!
10:03 AM
