Fail safety engine mode - Mustang Evolution
Old 08-30-2013, 12:11 AM   #1
Jon5.0BOSS's Avatar
Car doesn't move and my tuner says its my throttle body I was getting bad gas mileage so I switched it back to stock changed my tune to stock even got a new tune but no go still can't figure out what to do.. This is my buddy's 2005 gt my guess is he fried something electrical like TPS or his ecu do anyone have any ideas? Just trying to help my buddy out
Jon5.0BOSS is offline   Reply With Quote
Old 08-30-2013, 11:16 AM   #2
lucio's Avatar
Does it start ??
lucio is offline   Reply With Quote
Old 08-30-2013, 02:16 PM   #3
Jon5.0BOSS's Avatar
Turns on but doesn't move
Old 08-30-2013, 02:24 PM   #4
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
The throttle body position sensor on the 2005-2009 GT's is very touchy. I would bet that the TPS spring is adjusted wrong. This exact same thing happened to my 2007 GT when installing a larger throttle body. I couldn't get the adjustment right so I had the car towed to Ford (because it wouldn't start). It ended up being the TPS was out of adjustment. If that spring is not perfect, the car isn't going to start and if it does, the idle is going to be choppy.
This is where I would start, I hope this helps! Keep us posted and we can help you troubleshoot.
Also, check this thread out. This should be helpful! bbk throttle body - The Mustang Source - Ford Mustang Forums. Fail safe mode should clear the second your TPS voltage is correct!
-Dan
Old 08-30-2013, 02:37 PM   #5
Jon5.0BOSS's Avatar
I had I bigger throttle body on but I switched it back to stock shouldn't the eliminate the spring theory
Old 08-30-2013, 02:57 PM   #6
Jon5.0BOSS's Avatar
2005 mustang gt Throttle actuator comtrol system forced idle And throttle actuator control sustem stuck closed
Old 08-30-2013, 04:52 PM   #7
anthonyrc618's Avatar
My 05 GT 5 spd just went into this fail safe engine mode. It happened once before while I was driving. I was still able to drive, it was just really rough. It wouldn't let me into the upper rpms at all
anthonyrc618 is offline   Reply With Quote
Old 08-30-2013, 07:21 PM   #8
Edmr's Avatar
Hello, I had a similar problem with my F150. It turned out to be a dirty throttle body. I cleaned it with a tooth brush and some intake cleaner. Problem went away. Now I clean the throttle body every time I clean the air filter.
Edmr is offline   Reply With Quote
08:16 AM
