the driveshaft hits my gt body - Mustang Evolution
Old 09-04-2013, 04:57 AM   #1
I have a problem with my 2006 gt after installing eibach pro-kit springs the driveshaft hits the car body from below in hard launches or power shifting is there any solution for this?
I have 20" wheels
One-piece driveshaft
Eibch pro-kit lowers the back by 1.5"
Help please
ToRnAdO is offline   Reply With Quote
Old 09-04-2013, 08:19 AM   #2
Depack21's Avatar
There must be something wrong with the driveshaft because I'm lowered 1.5 with sr springs and I have no problem. I would get it checked out before it breaks
Depack21 is offline   Reply With Quote
Old 09-04-2013, 09:41 AM   #3
Could it be intended or something?
Old 09-04-2013, 09:56 AM   #4
Aggiesrok's Avatar
Have you checked your tranny mounts? Or your upper control arm maybe messed up.
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 09-04-2013, 09:59 AM   #5
The bushings of the control arms are old
Old 09-04-2013, 10:01 AM   #6
Aggiesrok's Avatar
Originally Posted by ToRnAdO View Post
What about them?
They could be loose. I think the upper control arm may be the problem. May have broke or busted a weld. It keeps rear end pinion angle correct.
Old 09-04-2013, 10:10 AM   #7
OK I'll check it
Old 09-04-2013, 10:12 AM   #8
Gibby's Avatar
If you lowered it you need an adjustable upper control arm to correct your pinion angle
Gibby is offline   Reply With Quote
Old 09-04-2013, 10:20 AM   #9
Can't just use the stock one?
Old 09-04-2013, 01:06 PM   #10
Gibby's Avatar
I wouldn't.
Old 09-04-2013, 01:09 PM   #11
I wouldn't.
Do I have to install the lower control arms too?
Old 09-04-2013, 01:18 PM   #12
Gibby's Avatar
I would it'll get rid of your wheel hop
Old 09-04-2013, 01:30 PM   #13
OK thanks bro
Old 09-04-2013, 01:38 PM   #14
Site Sponsor
Sponsor
AMWill's Avatar
I agree it sounds like a worn out bushing allowing extra free play. Make sure to check all the bushings in your whole suspension too. If one is old and worn out, chances are there's others on their way out.
Pinion angle is very important too. Make sure you get your adjusted at your earliest convenience at the very least.
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 09-04-2013, 02:16 PM   #15
Shane
OK I will, thanks man
Old 09-04-2013, 08:47 PM   #16
Aggiesrok's Avatar
The stock upper control arm isn't adjustable. It also might be the panhard bar. The stick one is not adjustable and when you lower the car it pushes the rear axle towards the driver side. You can measure it using the fenders and the tires. Replacing the lower control arms helps with wheel hop dramatically. It could be a combination of all. If you get new lower control arms get adjustable or else you'll need relocation brackets for them since you're lowered.
« Anyone?! | nitrous? »
01:56 AM
