Suspension updated & meaner - Mustang Evolution
Old 09-06-2013, 06:33 PM   #1
RedSleeper's Avatar
Currently on now:
•SR lowering springs 1.5 front and rear
•SR tower brace strut
•j&m chamber plates
Future upgrades:
•Tokico struts / shocks
•full replacement on all bushings (replace with prothane)
• steeda bumpsters and x5 ball joint
•Lower and upper steeda control arms
•replace the tie rods
---The picture with 4 pictures on it.---- the top two is before.. The bottom two is after (modded).
-Will have a clean motor bay after transmission is replaced.-
ID:	127723   Click image for larger version
ID:	127725   Click image for larger version
ID:	127727   Click image for larger version
Loving the days when you travel down to Mexico to push your car to the limits!
RedSleeper is offline   Reply With Quote
Old 09-06-2013, 07:00 PM   #2
Looks awesome
Old 09-06-2013, 07:20 PM   #3
RedSleeper's Avatar
Looks awesome
Thanks!!
Old 09-06-2013, 08:13 PM   #4
Rm360's Avatar
Nice stance! Your car looks great!
Old 09-06-2013, 08:56 PM   #5
RedSleeper's Avatar
Thanks!
Old 09-10-2013, 12:24 PM   #6
dmarq's Avatar
are camber plates and adj pan hard bar a necessity with these springs or is the 1.5 drop enough to keep things cool? I do plan on upgrading the lca's and PH bar in the future however...just wondering if i need to spend $600 right now, or is having just the springs fine?
dmarq is offline   Reply With Quote
Old 09-10-2013, 12:29 PM   #7
RedSleeper's Avatar
I recently found out the miles on your car will play big part.
If you have maybe under 60k springs and chamber should be fine.
Because of my miles I have to get completely new shocks & struts for the lowering, along with new rubbers & ball joints / bumpsteers. Which I'm going do very eventually.
I haven't got the chance to drive my car over 1 mile due to transmission. So I can't give you a straight out answer.
It does feel good driving around the block, felt it springs and strut tower was all it needed.
However as I said I haven't drove over 1 mile.. And I can't even go over 40mph without breaking my motor.
Old 09-10-2013, 12:47 PM   #8
Doe_Rae_mi's Avatar
Why didn't u just fix the transmission instead of all this supsension stuff? Looks good btw
Old 09-10-2013, 01:02 PM   #9
RedSleeper's Avatar
I am getting transmission replaced.
Had to wait 2 weeks for it to be built, now one more week for them to send it. Along with my torque converter 3k stall.
I have appointment for shop on 16th.
I was just doing suspension while I was waiting on transmission parts. (Diff shop for trans)
And thanks!
Old 09-10-2013, 01:06 PM   #10
Doe_Rae_mi's Avatar
And thanks!
Ahh I see nice!
Old 09-10-2013, 01:09 PM   #11
RedSleeper's Avatar
Ahh I see nice!
Yeah! Taking time is all. d:
Transmission is gonna b a badass with the torque converter seeing that the transmission is street fighter tci rated for 850hp
Old 09-10-2013, 04:19 PM   #12
dmarq's Avatar
Sounds good, I have 32k on it right now
Old 09-10-2013, 04:38 PM   #13
RedSleeper's Avatar
Sounds you'll be fine with just lowering springs & chamber plates.
You don't need new bushings.
Ball joint might be needed depending on how your car responds to the lowering springs.
I would recommend get them after you install the lowering springs and chamber plates. So you'd know how well your car responds to the alignment (geometry levels?)
You can always add control arms, pan, strut tower brace for much better handling.
It all comes to how strong, stuff, firm you want your suspension to be.
Lowering springs, chamber plates would've done the trick if I had under 50k miles.
But that was not the case. Lol
Hope I give good help & advices! These above are what I've learned so far.
Old 09-11-2013, 09:15 AM   #14
dmarq's Avatar
I appreciate the help, bro.
Old 09-11-2013, 10:31 PM   #15
RedSleeper's Avatar
No problem
Old 09-12-2013, 07:06 AM   #16
garbill2003's Avatar
All I used was the camber bolts when I lowered mine. It has front and rear steeda sway bar adj panhard steeda sports springs. I have put it to the test and it handles well. No more body roll but I do need bumpsteers to fix my rough road problem and a good break upgrade
garbill2003 is offline   Reply With Quote
Old 09-12-2013, 07:38 AM   #17
RedSleeper's Avatar
How many miles on yours?
Old 09-12-2013, 07:55 AM   #18
On the car or suspention?
Old 09-12-2013, 07:59 AM   #19
RedSleeper's Avatar
Struts & tower and the bushings
Old 09-12-2013, 08:07 AM   #20
Probably 3000 miles
Old 09-12-2013, 08:11 AM   #21
RedSleeper's Avatar
Probably 3000 miles
Oh that's good.
Easy to tackle the rattle, loud sound if lower car.
I gotta do whole thing lol...
Old 09-12-2013, 08:15 AM   #22
The install didn't take long and it handles well
Old 09-12-2013, 08:15 AM   #23
RedSleeper's Avatar
Update on parts for my car-
I'm ordering
- X5 ball joint steeda
- steeda bumpesters
- complete bushing prothane
- and possibly but most likely struts / shocks tokico
To go with the lowering 1.5 I have on.
Within few days so it can be installed after my transmission is replaced.
---------- Post added at 09:15 AM ---------- Previous post was at 09:15 AM ----------
Yeah I bet.
I can't wait drive my ):
Only 4 more days for the shop!
Old 09-12-2013, 08:21 AM   #24
Steeda makes excellent parts so they are who iam sticking with
Old 09-12-2013, 08:24 AM   #25
RedSleeper's Avatar
Oh yeah!
+ on steeda! Such a amazing item.
Hell I love the steeda intake on mine car (;
Old 09-12-2013, 08:28 AM   #26
Their suspention parts is where its at in my opinion
Old 09-12-2013, 08:30 AM   #27
RedSleeper's Avatar
Intake steeda are pretty good as well.
Old 09-12-2013, 08:56 AM   #28
I believe that
Old 09-13-2013, 03:44 PM   #29
RedSleeper's Avatar
Just ordered!
-Prothane Total bushing kit
-Steeda Bumpsteer Kit
-Steeda X5 Ball Joint Kit
-2 Replacement Front Outer Tie Rod End
-2 Replacement Front Inner Tie Rod End
Will get little bit more perhaps next month.
For now it's enough. Considering the fact I'm also doing transmission & exhaust.
Old 09-13-2013, 03:59 PM   #30
mgwarrior350's Avatar
How do you like the springs
mgwarrior350 is offline   Reply With Quote
Old 09-13-2013, 04:12 PM   #31
RedSleeper's Avatar
I love it, even though I only drove it around the blocks. Handled pretty very good, sexy! Looks much better. I don't know why ford made it 4x4 look in the first place.
Couldn't do above 40mph without breaking my motor.
Still waiting to replace my transmission / torque converter which should happen by next week.
Old 09-19-2013, 03:28 PM   #32
RedSleeper's Avatar
Drove my car today.
Man suspension feel 2 times better in big curves, etc. went easy on her today because of rain.
Can't imagine how much better it'll be running with more suspension parts I have on the way!
Old 09-24-2013, 12:10 PM   #33
Drove my car today.
Don't forget them breaks they are a must have Wance you start hammering it threw the turns
Old 09-24-2013, 02:54 PM   #34
Send a message via AIM to Destination S19
Looks like more than 1.5" to me. The adj. panhard bar should be required on that drop and adjustable camber plates are a really good idea, not to mention shocks/struts should be done at the same time as the springs. The factory shocks aren't valved for the different spring rate and drop.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 09-24-2013, 08:05 PM   #35
RedSleeper's Avatar
Obviously you didn't read the first page.
It's coming along.
11:33 AM
