Gears? - Mustang Evolution
Old 09-11-2013, 05:55 AM   #1
Jsansom's Avatar
Gears?
Can anyone tell mr what gears I have?
Jsansom is offline   Reply With Quote
Old 09-11-2013, 06:03 AM   #2
tc x 4's Avatar
Check the code on the driver's side door jamb. If they've been changed, I can tell you how to figure it, but you have to Jack the rear up.
Old 09-11-2013, 06:25 AM   #3
Jsansom's Avatar
I looked online it says 3.55
Old 09-11-2013, 07:02 AM   #4
Aggiesrok's Avatar
If you think its been changed from stock and want to calculate it. You need to know tire height along with rpm and speed in order to calculate it. Just measure ground to center of wheel and double it. Then you can use a gear ratio calculator online.
Old 09-11-2013, 07:07 AM   #5
I bet 3.31
07gt070207 is offline   Reply With Quote
Old 09-11-2013, 07:19 AM   #6
tc x 4's Avatar
Is that using the code?
Old 09-11-2013, 08:44 AM   #7
Jsansom's Avatar
No that's what I could find about the car. 08 shelby gt
Old 09-11-2013, 08:57 AM   #8
Jsansom's Avatar
http://m.autoblog.com/2007/06/13/off...ord-shelby-gt/
Old 09-11-2013, 08:58 AM   #9
Torchredfrankie's Avatar
Check deff cover my 09 GT came with 3.55s and it says it on the cover.
Torchredfrankie is offline   Reply With Quote
Old 09-11-2013, 09:00 AM   #10
jellyroll's Avatar
If you are running an Automatic it is most likely a 3.31 (this is what I currently have and your RPM is exactly what I am running at the same MPH).
Take a look under the car at the rear axle. There is a tag on the axle with the gear ratio.
2008 GT/CS - {SLP Loudmouth Axle Back Exhaust- SR Strut Tower Brace - Raxiom Sequential Tail Light Kit - C&L Street CAI - Bama Tune - FRPP Lowering Springs - FRPP Rear Sway Bar - FRPP Struts & Shocks - BMR TCA032 LCAs}
jellyroll is offline   Reply With Quote
Old 09-11-2013, 09:26 AM   #11
Jsansom's Avatar
Mine is a 5spd and ill look at it during lunch
Old 09-11-2013, 09:37 AM   #12
jellyroll's Avatar
From what I understand from reading some of the posts here the automatics are 3.31 and the manuals are 3.55 standard from the factory.
I could be wrong, but slide under the car and check the rear axle for the tag. Also as someone else has said it will be listed as a code on your door tag.
Old 09-11-2013, 09:51 AM   #13
Premium packaged GTs came with 3.55s I think and it was also a option.
Old 09-12-2013, 07:33 AM   #14
garbill2003's Avatar
Cars could be order with different ratios check the tag on the rearend and the door tag. I would say you have 3.31s in it. I have a gt premium and its a standard with 3.31s. My friend has a gt just the bace model and it has 3.55s in it
garbill2003 is offline   Reply With Quote
Old 09-14-2013, 01:39 AM   #15
It was a option out of the factory
Old 09-14-2013, 02:59 PM   #16
This is correct
MattNj is offline   Reply With Quote
Old 09-14-2013, 03:13 PM   #17
KATO's Avatar
GEARS
My 07 GT. Originally came with 3.31 Gears on my Automatic. I've since changed it to 4.10 Gears, and it's great.
Old 09-14-2013, 03:13 PM   #18
Franco09GT's Avatar
3:31, mine is a 5 speed & that's what my rpm was at 70mph. Your differential should have a sticker that says your gear, mine did when I swapped them with 4:10
Franco09GT is offline   Reply With Quote
Old 09-24-2013, 12:12 PM   #19
How's the gas mileage with the 4.10s
Old 09-24-2013, 01:37 PM   #20
KATO's Avatar
It's SoSo, Yes I noticed a difference. It does seem a little better in the city driving, more so than the HWY.
Old 09-24-2013, 01:50 PM   #21
I picked up a brand new set of 4.10s for $100 but iam not sure if I want to uses them I drive a lot . I think 3.73s would be better for me
Old 09-24-2013, 01:50 PM   #22
I'll take them off your hands
Old 09-24-2013, 01:51 PM   #23
Ha ha yeah I bet but with shipping and so on you would probably be paying the Same
Old 09-24-2013, 02:01 PM   #24
KATO's Avatar
3.73 would not be a bad choice, and not that much different than the 4.10. But you probably will get a better gas mileage.
Old 09-24-2013, 06:20 PM   #25
Jsansom's Avatar
Well I finally crawled under there and the tag says 3.55. So now my nxt question is would it but worth gettin 3.73. Bc I drive lil over 30 miles each way to work daily.
Old 09-24-2013, 06:32 PM   #26
You could go 3.90s
Old 09-24-2013, 11:02 PM   #27
Yes. Maybe even 4.10s, just drive 60mph'ish and you will be good. The thrill when you get on the pedal will be even better.
Old 09-24-2013, 11:49 PM   #28
KATO's Avatar
NO, If you have 355, then it does not make any sense getting 3.73. Too close of gears for a noticeable difference. Go with 4.10. Seriously, from 3.55 to 3.73 you will not notice anything, just a Lighter Wallet.
Old 09-24-2013, 11:50 PM   #29
MidnightBlueGT's Avatar
+1^
Old 09-25-2013, 10:00 AM   #30
BadAssStang07's Avatar
Would 3.90s be good since I got 3.55, I really need some advice cause I've been thinking about going higher on the gears.
BadAssStang07 is offline   Reply With Quote
Old 09-25-2013, 10:03 AM   #31
Why not go 4.10's? From what I've read the mpg difference isnt as bad as people say, when I switched to 3.73's I didnt drop really from my stockers.
I think 3.90's have more whining problems (what ive read from here but not sure)
Old 09-25-2013, 10:03 AM   #32
3.90s is a excellent choice
» Members Mustangs
Tonka
Borii
89 gt
BAD CO.
Add your Mustang
05:17 PM
