Hood issues - Mustang Evolution
Old 09-16-2013, 02:51 AM   #1
Midnite's Avatar
Hood issues
So I have an 08 gt and when I am going above speeds of 70 plus the hood looks like it is lifting up on me not a whole lot but it makes me nervous! I am curious if any other peeps are having this! I was thinking about putting in pins pins but I don't really want to on a stock gt hood unless I have too!
If pins are my only option where is the best place to locate them,
---------- Post added at 03:51 AM ---------- Previous post was at 03:49 AM ----------
And I have tried adjusting the rubber stops up but in still has a little lift at high speed!
Midnite is offline   Reply With Quote
Old 09-16-2013, 04:45 AM   #2
Ubnbit's Avatar
Look at primer2tones alternative to standard hood pins. That setup would look sweet on ur car.
Old 09-16-2013, 06:12 AM   #3
Midnite's Avatar
I tried to google that but couldn't get a decent response does am sell them
Old 09-16-2013, 07:23 AM   #4
jellyroll's Avatar
Hi Midnite,
I have the same issue. Sometimes I wonder if the hood is going to let loose on me, however it sounds like it is normal if you are also seeing the same thing.
Anyone else?
2008 GT/CS - {SLP Loudmouth Axle Back Exhaust- SR Strut Tower Brace - Raxiom Sequential Tail Light Kit - C&L Street CAI - Bama Tune - FRPP Lowering Springs - FRPP Rear Sway Bar - FRPP Struts & Shocks - BMR TCA032 LCAs}
jellyroll is offline   Reply With Quote
Old 09-16-2013, 07:24 AM   #5
Midnite's Avatar
It is creepy and I think I am going to have to pin it just to be sure
Old 09-16-2013, 02:26 PM   #6
maldog's Avatar
Region: Nevada
It's a common problem with the S197 hoods lifting up like that at those speeds.
If you put the hood pins like stated it will stop the hood lifting issue. Remember the hood is fiberglass so not a bunch of weight holding it down.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 09-16-2013, 02:45 PM   #7
I find it weird that the 05-09's have that issue "hood ballooning" (I had it on my 2006, even with an aftermarket steel hood). On my 2010 GT with the OEM hood, it doesn't move at all.
Rice Eater is offline   Reply With Quote
Old 09-16-2013, 03:29 PM   #8
Roguestang's Avatar
Coreect me if I'm wrong, but isn't there adjustable rubber hood stops near the grill you can adjust to take up that "slack"?
(I have them, but I own a New Edge and a Fox)
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 09-16-2013, 04:03 PM   #9
^ Should be two on the 05-09s
Old 09-16-2013, 05:20 PM   #10
maldog's Avatar
Region: Nevada
The rubber stops don't do anything to help the problem. The problem with the S197 hoods lifting is because of the design of the front end, at higher speeds the front lip allows to much air entering the engine bay causing the hood to flutter up and down.
I've read numerous articles about this problem from ford engineers and they say it was just a design problem that snuck by them lol
Old 09-16-2013, 05:25 PM   #11
Roguestang's Avatar
Ah ok. I figured there had to be some kind of adjustment that could be done with either those rubber bushings or even the hood locking mechanism. I had to finagle with mine when I got an aftermarket hood to get it just right. Welp hood pins FTW!
Old 09-18-2013, 10:39 AM   #12
Rogue Slider's Avatar
I've never noticed the hood lifting at those speeds. I will check that out today when I hit the freeway.
Rogue Slider is offline   Reply With Quote
Old 09-18-2013, 12:41 PM   #13
dmarq's Avatar
I take mine to 110+ daily and I've never seen anything like that...that sucks.
dmarq is offline   Reply With Quote
Old 09-18-2013, 12:43 PM   #14
RedSleeper's Avatar
Mine lil bit very tiny at 130+. x: *whistles*
Loving the days when you travel down to Mexico to push your car to the limits!
RedSleeper is offline   Reply With Quote
Old 09-18-2013, 07:38 PM   #15
hubbs's Avatar
Mine and my girlfriends both do this same thing. It's so minor that I don't even care about it. I'm probably gunna get good pins when I get a cervini hood
hubbs is offline   Reply With Quote
Old 09-20-2013, 02:11 PM   #16
Midnite's Avatar
Well I said screw it and got some pins I love the way they look anyway and just did a 300 mile road trip a rather fast trip and no flutter at all!!! I will post pics when I get back in town!
Old 09-20-2013, 05:24 PM   #17
Invision27's Avatar
Ever since I change my bumper and hood, mine does it bad now. I thought it was just me but now I'm seeing evening has the same problem
Invision27 is offline   Reply With Quote
08:21 AM
