Water-logged 06GT - Mustang Evolution
Old 10-18-2013, 06:21 AM   #1
Watchmana7's Avatar
Water-logged 06GT
The rain has stopped, but I am still hearing water sloushing around in the Stang! While driving, over my left shoulder I can hear water inside a compartment. I thought there was supposed to be a way for the water to drain away on these convertible tops? Can some give me a solution for this water problem?
Watchmana7 is offline   Reply With Quote
Old 10-18-2013, 06:26 AM   #2
Mustang81596's Avatar
In my 01 it gathers behind my back seat. Crawl back there and look where the convertible top folds down when you put it down. It may be there
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 10-18-2013, 07:28 AM   #3
my girlfriend's 06 ford five hundred gathered water in the ****in doors! I drilled a couple small hardly noticeable holes in the bottom haha
Old 10-18-2013, 07:55 PM   #4
dylanmullins's Avatar
Is the passenger floor wet
dylanmullins is offline   Reply With Quote
Old 10-18-2013, 10:02 PM   #5
Badinuf's Avatar
I think you need to look in the trunk.
2007 Torch Red Mustang GT, Parchment Leather, Saleen Supercharger, SCT X-Cal Programmer,brenspeed.com tunes, Tuned by X-Act Dyno (Tempe, Az) 425rwhp, 4:10 Gears, Axel-back MAC exhaust, Dashhawk OBD-II Computer Monitoring System, Sequential Tail Lights, Halo Driving Lights, Eagle Eye Headlights with 6000K HID's, Clear Turn Signal Lenses, Projector Switchback Bulbs, Painted White LeMans Style Stripes, CDC Aggressive chin spoiler, Billet hood pins, Pirelli P-Zero P255 40 ZR19 wheels mounted on 2014 Mustang GT Wheels
Badinuf is offline   Reply With Quote
Old 11-04-2013, 06:04 PM   #6
Blown05's Avatar
check by your cabin filter quick!!!! that drain hole can get clogged and mine got clogged and filled my entire car with water to the point had to cut the carpet out and get a new one... pain in the butt, but couldnt leave the inside alone with all the carpet out
stang is quite now
ID:	135211   Click image for larger version
Blown05 is offline   Reply With Quote
Old 11-04-2013, 06:29 PM   #7
Watchmana7's Avatar
Where is the cabin filter located?
Old 11-04-2013, 06:53 PM   #8
Blown05's Avatar
open the hood it is under the plastic that meets the windsheild my hold compartment right there had about 6 inches of water in it
this other picture was not a happy day after i found it... this happend after car was packed and everthing was leaving for mustang week and got in to leave and my car had 2 inches of water in it
ID:	135225   Click image for larger version
Old 11-04-2013, 06:53 PM   #9
Blown05's Avatar
its right behind the battery u have to take that plastic peave off
Old 11-04-2013, 11:49 PM   #10
tc x 4's Avatar
There is also two drains for the cowl. They are located down low on the firewall, just stick your fingers in there and pull the crap out. They will dump water into the car if clogged.
Old 11-06-2013, 05:48 AM   #11
Watchmana7's Avatar
I checked the cabin filter and there is no water there. The water sound I hear is coming from behind me over my left shoulder as I sit behind the steering wheel.
---------- Post added at 07:48 AM ---------- Previous post was at 07:45 AM ----------
Thank you, I checked the drains for the cowl as well, and there was no accumulation of water.
Old 11-06-2013, 06:00 AM   #12
05MUSTANG4.0L's Avatar
Mines was doing the same thing and getting all my fuse box wet and messing up my electronics on the inside. It turned out the water was coming in thru the gasket were the antenna cable comes in
05MUSTANG4.0L is offline   Reply With Quote
Old 11-06-2013, 06:00 AM   #13
Watchmana7's Avatar
I have looked and so far I have not found the water. I know it is there, but have not been able to find where the water is collecting. Is there a compartment where the water collects to drain from the convertible top around the left rear roof post? I know it is really not a roof post on a convertible.
Old 11-06-2013, 06:12 AM   #14
It's not me, it's you.
primer2tone's Avatar
I imagine the water would drain out at the rear of the side skirts. You might want to remove it and see if it has anything like that.
Old 11-15-2013, 05:25 PM   #15
you might check in your cowl under where the wipers are. I found my passenger side floor board pretty wet and my driver side floor board just a little wet. I got tired of messing with it tho so I just put my mats down back over them. supposedly the area under the cowl has a drain that gets clogged pretty easily. I couldn't find where mine was leaking from cause it was not clogged and I got tired of messing with it so I just quit.
Old 11-15-2013, 06:07 PM   #16
Lous2006LLGT's Avatar
I had the same problem this past spring - had to take it to dealer and $350 later, problem solved. The water is in your rear quarter panel. They had to remove the rear seat, plastic covers right below the quarter window and the lower side skirt/spoiler panel. Even then, they still had a a tough time getting the water out. They brought me out to show me where the water was and there was no way I could have gotten to it and removed at home. Good luck
Lous2006LLGT is offline   Reply With Quote
Old 11-15-2013, 06:35 PM   #17
That's ridiculous
12:11 AM
