very strange start up problem. I need help - Mustang Evolution
Old 10-26-2013, 03:49 PM   #1
I have a strange problem with my mustang, and it is driving me crazy. I hope someone can help. Here it is. I have a 2007 mustang gt with a 4.6L engine. I set the little screen in my dashboard to my mpg setting. I can turn my car off and walk away. When I return to my car, put the key in the ignition. I turn the key to the on position without starting the engine, the screen is still at the mpg. As soon as I start the engine, the screen goes to its default position of simply stating my mileage. The battery will also die within a month of the car not being driven. I have checked every single relay that has to do with the starting system; they are all ok. I have had the battery, alternator, and starter motor checked out. All are ok. I just replaced the ignition switch in the car, and that didn't help the problem either. I am out of ideas on how to fix this, and I am asking anyone who might have an idea of what I can check.
coolguy21433 is offline   Reply With Quote
Old 10-26-2013, 05:39 PM   #2
Mfore33's Avatar
Do you have any aftermarket radio stuff in the car. Amp ect..?
Old 10-28-2013, 11:51 AM   #3
No, the entire car is all stock.
Old 10-28-2013, 12:03 PM   #4
Torchredfrankie's Avatar
Is there a cd stuck in the radio? I had a cd stuck in the radio and that killed my battery because the cd will skip all the time.
Torchredfrankie is offline   Reply With Quote
Old 10-28-2013, 04:16 PM   #5
No, there are no cds stuck in the player. Just checked.
Old 10-29-2013, 12:43 AM   #6
Jayjay's Avatar
Have you checked your battery at a different location.. I had a similar situation and was my battery. Checked it at autozone twice and told me my battery was good, took it to dealer and said battery was bad... I didn't believe them since autozone told me it was good. I bought a battery from ford with 5 yrs warranty and it fixed my problem. 6 months later my alternator gave up and got replaced.
Jayjay is offline   Reply With Quote
Old 10-29-2013, 05:03 AM   #7
Mfore33's Avatar
I had my alternator checked and it was good. Similar problem like yours. Turned out the diode in the alternator was bad. Not getting a proper charge and causing a slow drain. I think the diode kit was under 30 dollars. Other than that check the fuses in the morning before the car get cranked for any signs of heat. That could indicate a circuit short of some kind. Also check for corrosion on battery post and cables. I had a truck that wouldn't start after sitting a while and it was the inside of the cable connectors that had a corrosion on them. I used a wire brush to get them shiny an it started right up. Good luck.
09:57 PM
