Mustang GT suspension - Mustang Evolution
Old 11-17-2013, 12:34 AM   #1
Graham1992's Avatar
This has probably been beat to death.. I have stock suspension and want to look into a simple nice setup. Not looking to take corners at 200mph+. Just want a good "street/strip" application for hooking. Wanting a simple nice setup.
What are the best rear lower and upper control arms? wanting a good setup on the front and back without going all out and wasting money. Like i said, handling is not what I'm after at all. So what would i need for the front to help it hook in the back? What would i need for the back? And as always please and thank you!
PS: i have slicks, tires aren't the issue
Graham1992 is offline   Reply With Quote
Old 11-17-2013, 01:09 AM   #2
NewMtang's Avatar
Ford Racing Assembled Handling Pack - Coupe (05-14 GT)
Our Price $1,649.99 from AMERICAN MUSCLE. It drops the front and back 1.25" front and back.
Old 11-17-2013, 01:25 AM   #3
Graham1992's Avatar
like i said, not looking for handling.. just some struts and springs bub. I've already called about that kit and its for handling. via the name handling package. looking for a track package. lowering the car doesnt mean better launches and hooking, just means its lower and can handle curves..
Old 11-17-2013, 03:34 AM   #4
tc x 4's Avatar
Bmr lowers and upper. Stiffer rear springs, front sway bar and radiator support delete. The delete will take 60# off the front-end if I remember right. Relocating the battery to the trunk will help also.
Old 11-17-2013, 03:43 AM   #5
Franco09GT's Avatar
Bmr rear Lca's, qa1 rear adjustable shocks, sway bar delete. & some rear re-location brackets. & the bmr radiator support can save some weight
Franco09GT is offline   Reply With Quote
Old 11-17-2013, 05:05 AM   #6
Graham1992's Avatar
wow guys thanks. thats the answers i was looking for!
Old 11-17-2013, 03:39 PM   #7
Mile high JDF's Avatar
Well you do realize that a road course is called a track as well right... However mentioning you have slicks does imply that you're going to the drag strip
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-17-2013, 04:33 PM   #8
Some drag coilovers will do good. UPR has a decent set and are pretty cheap.
09:43 PM
