Halo - Mustang Evolution
Old 11-24-2013, 07:33 PM   #1
Coleton's Avatar
Halo
I want to get some halo's what's the best cheapest way to put them in my stang?
Coleton is offline   Reply With Quote
Old 11-24-2013, 07:42 PM   #2
MidnightBlueGT's Avatar
To purchase? eBay to put them in? DIY
Old 11-24-2013, 07:43 PM   #3
Coleton's Avatar
I was basically wondering what all do I need? Besides bulbs
Old 11-25-2013, 09:08 AM   #4
Kylemittelman's Avatar
Are you just installing leds into your existing headlights? Or are you buying a whole new halo headlight?
Kylemittelman is offline   Reply With Quote
Old 11-25-2013, 10:36 AM   #5
Coleton's Avatar
I would like to just put them in my existing head lights.
Old 11-25-2013, 11:00 AM   #6
You will need to disassemble the headlight using heat to access that area.
Old 11-25-2013, 11:07 AM   #7
Terminator's Avatar
They sell stock headlights with halos in them on AM much easier an comes with raxioms warranty so you won't have to worry if you did them correctly an install isn't too bad either
Terminator is offline   Reply With Quote
Old 11-25-2013, 09:32 PM   #8
Whole bumper has to come off. There's a top panel in the good that has to come off, has like six pins, then turn the wheels to access two other 10 mm bolts I think, then there's two other 10's way up under the wheel well trim that are a pain in the *** to get to, then underneath there's like 4 7/32 screws, then two more tens on top of the headlights, then the bumper comes off. Then there's two more screws underneath the headlight, both 10's I think, and the headlight comes out. Then bake them for 10 min at I think 250 degrees, (check on temp, I can't remember for sure) and then cut silicone with razor. Then install leds, re silicone , and put everything back.
This was all from memory so i might be missing something.
08:43 AM
