Cam to supercharger - Mustang Evolution
Old 11-26-2013, 09:19 AM   #1
Spaceghost's Avatar
An friend of my just cam out his car .....and he would like to know how hard is it to change over to sc...he brought an Roush m90
Spaceghost is offline   Reply With Quote
Old 11-26-2013, 09:24 AM   #2
MidnightBlueGT's Avatar
It's hard to understand what you're trying to say or ask.
Old 11-26-2013, 09:28 AM   #3
Spaceghost's Avatar
Sorry my fingers is typing right....my friend just put cam on his car...and now he just bought an s/c for it ....how hard is it to convert from cams to s/c
Old 11-26-2013, 09:47 AM   #4
Why would you have to convert? Just tune it to s safe power level
---------- Post added at 08:47 AM ---------- Previous post was at 08:47 AM ----------
He can keep his cams
KoolPwny is offline   Reply With Quote
Old 11-26-2013, 09:53 AM   #5
ColeJohnson's Avatar
No reason to convert.. Cams and s/c are two totally different things. They can both be upgraded independently.
2016 Comp Orange GT (current)
Old 11-26-2013, 10:53 AM   #6
Wolverine0587's Avatar
The right cams with the right tune will greatly improve your engines output with a S/C over a stock motor with just a S/C and a tune.
Wolverine0587 is offline   Reply With Quote
Old 11-26-2013, 11:18 AM   #7
Getn off's Avatar
More than likely your friend didn't install FI cams. To do it right, he will need to re cam for his blower. There are blower cams, and non blower cams. They allow for diff things. Whats 9 grand vs 7?! With this motor, I would forge things before a blower and cams.
Troy
Getn off is offline   Reply With Quote
Old 11-26-2013, 01:14 PM   #8
Originally Posted by Getn off View Post
More than likely your friend didn't install FI cams. To do it right, he will need to re cam for his blower. There are blower cams, and non blower cams. They allow for diff things. Whats 9 grand vs 7?! With this motor, I would forge things before a blower and cams. Troy
Well blower cams aren't that much different until higher boost. At 8-12lbs it won't be a big difference between say.. Blower cams and comp cam 270s
Someone correct me if I'm wrong.
Old 11-26-2013, 09:13 PM   #9
TorchRed6's Avatar
since were on the topic, what is the difference between cams for FI and normal ones?
TorchRed6 is offline   Reply With Quote
Old 11-26-2013, 09:31 PM   #10
Pretty sure it's just a different cam profile to help the cams handle increased air flow.
Old 11-26-2013, 10:45 PM   #11
Getn off's Avatar
Yes, lift and duration is much different.
As noted, either will work, but a lot of efficiency and hp/tq will be lost.
Troy
Old 11-27-2013, 07:35 AM   #12
TorchRed6's Avatar
so until you swap out the cams, you wont see the full potential of your charger?how does that work for v6s when hardly anyone will custom make them? are you just outta luck?
Old 11-27-2013, 09:36 AM   #13
Getn off's Avatar
Pretty much. Supply and demand.
All this on a six? 10k is a nice 4V!
Troy
Old 11-30-2013, 09:01 PM   #14
dont
you shouldn't convert... does not make sense
samawrabi is offline   Reply With Quote
09:46 PM
