Need help 2007 GT won't turn on - Mustang Evolution
Old 12-02-2013, 10:44 AM   #1
2007GT's Avatar
Last night I pulled my radio fuse under the hood trying to fix my CD error on my shaker 1000. It did not work so I went to the interior fuse panel and pulled out the cord above the fuse panel and was un able to get into that fuse panel and gave up. I connected everything back together that night. This morning I go to start my car and it won't even turn over. Nothing shows up on the instrument panel and the car won't come out of park even with the brake depressed. The lights work so the battery isn't dead. Please help.
2007GT is offline   Reply With Quote
Old 12-02-2013, 10:54 AM   #2
Screaming Mach's Avatar
Did you unplug the battery and let it reset?
Screaming Mach is offline   Reply With Quote
Old 12-02-2013, 10:58 AM   #3
2007GT's Avatar
I will when I get home tonight. I hope it will work.
Old 12-02-2013, 11:01 AM   #4
Yes I hope that's all it is I had some what of the same problem in my last car unplugged the battery for like 10 min and it was good after that .
Old 12-02-2013, 11:19 AM   #5
Fader's Avatar
Region: Idaho
This is why most repair instructions start with "Disconnect Negative Battery Terminal". Truth be told, that's likely all you would have to do to reset your stereo, too. Never work on any electrical part, under the hood, or in the cabin of your car without disconnecting the battery. One little short-circuit could fry some vital computer parts.
Fader is offline   Reply With Quote
Old 12-02-2013, 11:24 AM   #6
+1000
Old 12-02-2013, 11:25 AM   #7
bucko's Avatar
Almost sounds like a PATS issue (passive anti-theft system). If the PATS does not "reconize" the key (in the ignition), the starter will not ingage/spin. Hopefully the battery disconnect is a solution.
Old 12-04-2013, 03:57 PM   #8
Davo_281GT's Avatar
I like your quotes man...good stuff.
"A mans reach should exceed his grasp."
Davo_281GT is offline   Reply With Quote
03:24 PM
