Clutch - Mustang Evolution
Old 12-31-2013, 11:32 AM   #1
Invision27's Avatar
Clutch
How do you know if your clutch is bad
Invision27 is offline   Reply With Quote
Old 01-01-2014, 04:34 PM   #2
Coleton's Avatar
Go to 4th or 5th gear hit the gas and if your rpms raise faster than your speed you prob have a bad clutch
Coleton is offline   Reply With Quote
Old 01-01-2014, 04:45 PM   #3
Invision27's Avatar
Its just weird I can smell it burning and it seems like its onky slipping when the car is warmed up and inly in first
Old 01-02-2014, 10:38 AM   #4
Coleton's Avatar
First time using a manual?
Old 01-02-2014, 10:41 AM   #5
Invision27's Avatar
No I had manuel since I was 16 I never had one do this before like this
Old 01-02-2014, 11:01 AM   #6
Langer1099's Avatar
When my clutch went out on my Z28, it just got really soft. The pedal would stick really bad.
2009 Mustang GT Premium; FRRP 4.10 Gears, J&M Lower Control Arms, BBK Long Tube Headers, BBK Catted X Pipe, Pypes M80 Mid Mufflers, Pypes Pype Bomb Axle Back, JLT Series 3 Cold Air Intake, Bama 93 Octane Race Tune, Black Decklid Panel, Weathertech Mats, SVE Shifter and Shorty Antenna.
Langer1099 is offline   Reply With Quote
Old 02-11-2014, 10:21 PM   #7
kila07GT's Avatar
The clutch can slip on any gear! Usual signs are higher release than normal and the lack of free play that is present in normal systems. When a clutch plate and pressure plate are performing correctly the vehicle should start moving forward when the clutch pedal is a quarter of the way up. Not completely disengaging but enough to get the car crawling. If this is not the case then either your clutch has to be adjusted or replaced.
kila07GT is offline   Reply With Quote
Old 02-12-2014, 07:50 AM   #8
1lowGT's Avatar
What's problems you having with it?
Old 02-17-2014, 03:38 PM   #9
Are you 16 and a half?
Completely kidding. All clutches are a bit different, my test was always to drive up a long hill and press gas in 3rd or 4th and see if the RPM raise faster than your actual speed.
Arustik is offline   Reply With Quote
08:50 AM
