Need help! - Mustang Evolution
Old 01-02-2014, 07:57 AM   #1
BadAssStang07's Avatar
Need help!
So about a week ago my check engine light came on, I have the diablosport intune tuner and It told me that my car is running too lean, it went off after driving it a while but then I checked it again last night and the code is still on, I know running lean hurts the motor bad but does anyone know how to fix it or why It happened!?
BadAssStang07 is offline   Reply With Quote
Old 01-02-2014, 08:14 AM   #2
Torchredfrankie's Avatar
Any bolt ons?
Torchredfrankie is offline   Reply With Quote
Old 01-02-2014, 09:47 AM   #3
Yeah, I have a cai, tb spacer,and steeda udp
Old 01-02-2014, 10:26 AM   #4
Hmmm maybe the tune is the problem, the engine is not getting enough fuel.
Old 01-02-2014, 05:25 PM   #5
Roguestang's Avatar
+1
Are you using 87 with a 93 tune by chance?
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 01-02-2014, 06:46 PM   #6
Gmoney22's Avatar
Its most likely your air/fuel ratio if the problem is the lean gas. retune it and make sure you use the right grade your tune says.
Gmoney22 is offline   Reply With Quote
Old 01-02-2014, 06:56 PM   #7
Originally Posted by Roguestang View Post
+1
Haha no I'm not stupid, I have had the same tune for at least a year now and only messed up that one time
Old 01-02-2014, 07:17 PM   #8
Roguestang's Avatar
Ok, I was by no means trying to insult you. Just covering the basics. I've known some to accidentally load up the wrong tune, and think they are on a different setting; we're all human. But have you noticed any detonation? Pinging sounds?
Old 01-03-2014, 12:27 AM   #9
Pinging sounds? Where would it be coming from, could u please explain more.
Old 01-03-2014, 04:54 AM   #10
Roguestang's Avatar
Pinging is usually the sound of detonation, but if you haven't noticed it, chances are its not doing it. It could sound like a diesel engine chugging along, or even like a loose piece of metal banging around in the engine bay. Its hard to explain what it sounds like, you'd have to google it. But like I said, if you haven't noticed a difference in sound from the engine bay its probably not doing it.
Old 01-03-2014, 06:21 AM   #11
mystang50's Avatar
X2 you deff would of noticed it!
Old 01-03-2014, 06:21 AM   #12
Ok and if I did notice it, what would that mean the pinging sound? And what would it cause?
Old 01-03-2014, 08:00 AM   #13
Roguestang's Avatar
Here is a link to a wiki page on detonation.
http://en.m.wikipedia.org/wiki/Engine_knocking
Old 01-03-2014, 06:51 PM   #14
Edmr's Avatar
Did you pull any plugs? If your running lean the plugs will usually tell you. If the light went off you might have had some bad gas.
Edmr is offline   Reply With Quote
Old 01-04-2014, 06:57 AM   #15
I didn't try that. What would I look for on the plugs to tell?
Old 01-04-2014, 07:09 AM   #16
Edmr's Avatar
We'll if it is really bad they will be burnt/melted. A lean engine will run really hot and if left unaddressed will cause catastrophic damage. They may have white deposits on them and the ceramic could be cracked as well. If your light is no longer on or comes on from time to time you could have a bad O2 sensor. Good luck.
Old 01-05-2014, 06:24 PM   #17
Need help!
I've seen a intake manifold gasket leaking setting off a lean code, mass air flow sensor could set it off or as simple as a vacuum line loose of not installed correctly.
little rick is offline   Reply With Quote
Old 01-05-2014, 08:29 PM   #18
OmegaRedGT 2007's Avatar
Does your car run funny..my wife put 87 octance in my Pony and my car went nuts!!! I had to change my plugs and flush my fuel system.
OmegaRedGT 2007 is offline   Reply With Quote
Old 01-06-2014, 01:32 AM   #19
No, my car seems to run just fine, Idk what the problem is but I'm going to get it checked just to make sure.
02:05 PM
