Questions 08 GT - Mustang Evolution
Old 01-13-2014, 01:10 AM   #1
Scream's Avatar
Questions 08 GT
Alright 2 main things.
1) engine has a STEEDA CAI with a 87 Octane tune. Well when getting into higher speeds 50-70 then going to a stop ( holding in clutch then brake) the car will have a bad idle problem then sometimes die completly. Any ideas? Basic idle is fine.
2) car was in a side wreck not totalled that's why I got it Si cheap. Well the steering wheel was off centered so I figured an allignment will take care of it... It just made the steering wheel switch which side it was off. It is now off centered so that the left side is just a small amount still noticable. Is there a way to lossen the wheel to center it myself somehow? Thanks in advance! Its a 08 GT
Scream is offline   Reply With Quote
Old 01-13-2014, 09:53 AM   #2
sorry I cant help you on your questions, but just wanted to say that is a niceeeeeee lookin stang man!
skl1cent is offline   Reply With Quote
Old 01-13-2014, 10:10 AM   #3
Scream's Avatar
Haha I appreciate it man!
Old 01-13-2014, 10:14 AM   #4
Attachment 144502
if it came with a tuner you ought to be able to set the idle rpms. I had to do that with my bama sct tuner from AM on my v6 back when I had it. other wise you may have to get them to adjust the tune
Old 01-13-2014, 10:31 AM   #5
Scream's Avatar
It idles fine. It is just stopping at higher speeds. Like going on to an exit ramp and slowing down
Old 01-13-2014, 10:43 AM   #6
oddd
Old 01-13-2014, 10:43 AM   #7
Aggiesrok's Avatar
Are you getting a CEL? Do you have a tuner or were you just told that it had an 87 tune? If you have the tuner, you should be able to data log it and send the file for further evaluation.
Old 01-13-2014, 10:51 AM   #8
Scream's Avatar
No light. It was wrecked so airbag is deployed. Fixed soon. Airbag light, ABS, TCS, and stability control
Old 01-13-2014, 12:56 PM   #9
jellyroll's Avatar
Same question here with the steering wheel issue. It is pissing me off, since I just had it aligned. Steering wheel is off to the left just enough to notice it.
I thought about taking the wheel off too, but with the airbag I am not in any hurry to do it.
If you hear of a solution please post again!
Nice car by the way.
2008 GT/CS - {SLP Loudmouth Axle Back Exhaust- SR Strut Tower Brace - Raxiom Sequential Tail Light Kit - C&L Street CAI - Bama Tune - FRPP Lowering Springs - FRPP Rear Sway Bar - FRPP Struts & Shocks - BMR TCA032 LCAs}
jellyroll is offline   Reply With Quote
Old 01-13-2014, 02:36 PM   #10
Edmr's Avatar
For the steering wheel issue I would take it back to where you had I aligned and have them fix it. If not you could align it yourself. I use a couple pieces of galvanized sheet metal (2 under each front wheel with some grease in between) so that the wheels will turn easy. then just loosen the tie rod ends and adjust the steering wheel back into alignment.
Edmr is offline   Reply With Quote
Old 01-13-2014, 02:39 PM   #11
Scream's Avatar
I didn't even think about taking it.back to them haha. Ima have to this weekend
Old 01-13-2014, 02:41 PM   #12
SixBanger's Avatar
I apologize that I can't help, but I have to say, godd**n that thing is beautiful.
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 01-13-2014, 09:48 PM   #13
Aggiesrok's Avatar
Have you tried disconnecting the battery for 15-20 minutes a try to reset. You might try checking for codes with a tuner even though the CEL isn't lit.
Old 01-13-2014, 10:13 PM   #14
Try cleaning the throttle body and idle air control with carburetor cleaner
Topless fun is offline   Reply With Quote
Old 01-14-2014, 01:45 AM   #15
Franco09GT's Avatar
Sounds like your idle is surging. Mine does the same exact thing. I got cams in mine though & mines throwing a o2 sensor circuit slow response code. That's why mines doing it, I think. The engine light wouldn't come on either but it finally did one day & that's the code I got. Could be an o2 sensor maybe?
Franco09GT is offline   Reply With Quote
Old 01-14-2014, 11:01 PM   #16
Scream's Avatar
I still haven't found out what it is. Dropped it off today to get my side air bag replaced and seatbelt. As my dad pulled it into the shop the exhaust tip fell off lol. Any ideas on how to get over speed bumps without scraping ?
what does it take to outrun a GT? austinknoll Pre-2005 V6 Mustang 72 01-14-2012 01:19 PM
my 04 gt, vs 03 cobra and 2011 mustang gt secomejia 1996-2004 Mustang GT 57 01-04-2012 08:07 AM
GT or customize my v6 xhgwx Pre-2005 V6 Mustang 37 12-23-2011 01:17 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
08:25 PM
