Upgraded injectors - Mustang Evolution
Old 01-17-2014, 01:45 AM   #1
C_Dailey95's Avatar
Upgraded injectors
Does upgrading your injectors give any significant upgrade in power? Been thinking about changing them, also when Is I good time to swap spark plugs?
C_Dailey95 is offline   Reply With Quote
Old 01-17-2014, 02:16 AM   #2
Bennyhill's Avatar
No swapping fuel injectors is only recommended when adding a sufficient amount of power! Like a supercharger, or every bolt on possible, your stock fuel injectors will be suitable for a few combinations without changing.. I'm sure you could do full exhaust, cai, without changing them. Also if you change them you will require a tune!
Bennyhill is offline   Reply With Quote
Old 01-22-2014, 06:43 PM   #3
gt07's Avatar
about those plugs 4.6 3v says 100,000 don't wait they break off in the heads the tool to get them out is 60 bucks do it before 50,000 I know they are about ten dollars each money well spent ......check out you tube for removing 4.6 3v plug to see what I mean....and the injector are good for almost all bolt ons.... not super charger or turbos
gt07 is offline   Reply With Quote
Old 01-23-2014, 04:12 AM   #4
Bennyhill's Avatar
Buddy read the tread! Those injectors won't do anything for you! Until you start to upgrade! Your stock 29# an hour injectors are good for something like 400 fw hp.. And with most bolt ons you will not even see those numbers.. You are talking about spark plugs..
Old 01-23-2014, 08:36 AM   #5
gt07's Avatar
thanks but I was answering c_baily95 and it was more about the plugs then injectors. and I did read yours and I agree about the injectors
injectors not opening im new please help! mikedeck Pre-2005 V6 Mustang 12 10-29-2012 11:18 AM
CAI and 31 LB injectors southernstang00 Mustang Parts for Sale and Wanted 10 10-27-2012 01:30 PM
Very Nice Upgraded Vortech V1 S-Trim Kit (FULL KIT!! EVERYITHING)+ GAUGES AND PODS CodyNelson Mustang Parts for Sale and Wanted 16 09-30-2012 08:06 AM
Fuel injectors ?? stangstar92 1996-2004 Mustang GT 3 10-05-2011 04:59 PM
60 lb injectors question? CZYFAST 2011-2014 Mustang GT 27 07-19-2011 02:56 PM
10:38 AM
