brake broblem - Mustang Evolution
Old 01-24-2014, 11:26 PM   #1
brake broblem
Hi from Europe
What should I do to my 06 gt, brakes are good about 2 weeks
after bleeding end then them get soft, new mastercyl is in place 1caliper is replaced brakes are good and nothing doesnt look bad, HELP
Raceri is offline   Reply With Quote
Old 01-25-2014, 01:40 AM   #2
Brake broblems bucking buck, dude.
You need to CAREFULLY inspect the entire system, brake lines, brake hoses, EVERYWHERE that the brake fluid runs through. Look for any signs of seepage or leakage.
Its possible that the brakes weren't bled correctly, so you might try that again if you can't find any obvious signs of anything wrong.
Old 01-25-2014, 11:37 AM   #3
gt07's Avatar
check brake hoses in the front look for bulges if all is good then bleed master cyl by having someone pumping then hold the breaks and loosen brakes lines or if it has bleeder fittings.if there are fittings put a hose on the fitting and catch the fluid in a clear container look at the fluid carefully look for small air bubbles(one at a time front line repeating step one rear line) for a second while holding the brake not allowing the brake to hit the floor.....check the brakes if it does it again you may have air in the caliper you replaced do the same for the caliper......hope this helps
gt07 is offline   Reply With Quote
Old 01-25-2014, 03:17 PM   #4
gt07's Avatar
top off brake fluid
SS Brake Line install Horseplay Pre-2005 V6 Mustang 7 12-29-2013 06:03 PM
Brake Master Cylindar cjd_1986 2005-2010 V6 Mustang 0 03-07-2013 06:57 AM
12V Relay Brake Bypass? ColeJohnson Mustang Audio & Video 8 01-26-2012 09:22 AM
Lowering the 2012 5.0 Brembo Brake Package avengnd 2011-2014 Mustang GT 33 10-28-2011 07:47 PM
Most Popular Brake Pads Brent 1996-2004 Mustang GT 18 09-18-2011 10:29 AM
12:58 AM
