Automatic Shifter Loose - Mustang Evolution
Old 01-31-2014, 04:39 PM   #1
ElSaborAsiatico's Avatar
Region: New Mexico
For as long as I've had it, my '04 GT automatic has had a shifter that feels weirdly loose. When I put it into D, for instance, I have to jiggle it a bit to make it lock into place. This does not seem right at all, but this is my first Mustang, or Ford for that matter, so I don't know if this is normal or not!
If it's not normal, I'm wondering how expensive and/or difficult it would be to fix. It's annoying, but I can live with it unless/until it gets significantly worse.
ElSaborAsiatico is offline   Reply With Quote
Old 01-31-2014, 05:21 PM   #2
Mosified's Avatar
My shifter cable does that. I need a new one. It's fried in the middle from sitting on the stock h-pipe. I routed it away from it for now. But its on my bucket list. With a new Bullitt handle too
Old 01-31-2014, 05:24 PM   #3
Mosified's Avatar
*My shifter handle does that because of my melted cable*
Old 01-31-2014, 05:43 PM   #4
KSconvert's Avatar
Kegels.
I apologize that I can't actually help. I just couldn't miss a golden opportunity when someone complains about it being loose with the D.
2014 GT MT aka: Ruffian-
3.73 gears, Roush AB, BBR O/R x-pipe, JLT intake, BMR panhard bar, BMR lowers and brackets, FRPP 47# injectors, Lund E85 tune, SR springs, MGW shifter, 416rwhp/393rwtq
KSconvert is offline   Reply With Quote
Old 01-31-2014, 05:51 PM   #5
Mosified's Avatar
Originally Posted by KSconvert View Post
Kegels.
Ha haa!! I never thought of it like that Innocense is blind!!))
Old 01-31-2014, 06:30 PM   #6
Region: New Mexico
Kegels.
Now that you mention it though...but I guess I should take that to a different forum.
Old 01-31-2014, 08:41 PM   #7
KSconvert's Avatar
Haha sorry. In all seriousness though, I'd check the cable like Mosified suggested, or maybe get the console apart and see if there's something loose in the bracket. A bolt or something might've just worked itself loose, considering the car is 10 years old.
Old 01-31-2014, 08:44 PM   #8
Mosified's Avatar
Just squeeze under there with a flashlight. Its exactly in the middle on the loop. The outer layer has play since its loose and on its way out the door.
Old 01-31-2014, 08:55 PM   #9
if you take the consol out and pop that white clip u can use your shifter like a slap shifter and drive more like a manual
KraftDinner is offline   Reply With Quote
Old 01-31-2014, 10:34 PM   #10
32GT32's Avatar
Guys I have the same problem on my automatic 10 gt! Any way to make my shifter tighter?
32GT32 is offline   Reply With Quote
Old 02-01-2014, 01:53 AM   #11
Jayjay's Avatar
My 06 was the same when I bought it, didn't pay much attention to it. On one service visit to get my oil change they topped my fluids, my tranny was low on oil.
When I got it back the shifter was stiffen again, not sure if the low oil was the cause of it but did help
Jayjay is offline   Reply With Quote
Old 02-01-2014, 02:30 AM   #12
You put oil in your transmittion ? ^
Old 02-01-2014, 02:33 AM   #13
Jayjay's Avatar
Transmission fluid
2011 3.7L V6 6R80 to MT-82 swap completed 3.7Cyclone 2011-2014 V6 Mustang 17 12-24-2014 01:00 AM
Automatic short shifter KraftDinner 1996-2004 Mustang GT 4 01-27-2014 12:12 PM
2014 select shift automatic shifter AmericanBulldog 2011-2014 V6 Mustang 3 01-15-2014 03:11 PM
"T" Handle Shifter Swap 93mstnglx 2.3 Mustang 0 09-30-2012 11:54 AM
Short Throw Shifter bmabbott Pre-2005 V6 Mustang 11 08-17-2011 04:03 PM
08:25 PM
