Charging System Problems - Mustang Evolution
Old 02-02-2014, 11:09 PM   #1
2 Stangz's Avatar
Region: Nevada
Okay, so my battery is corroding pretty bad. Also, I'm having a problem with my lighting which makes me think it's a charging issue. For example; I open my door (engine off) and the dome lights smoothly fade on. If I open my door with the engine on, the dome lights struggle to smoothly fade on. I've noticed while in reverse my reverse bulbs flicker slightly and my license plate lights do the same, only while the engine is on.
I'm taking it to Ford tomorrow around 2:00 PM, but I'd like to get some insight from you guys first.
Cracked battery, regulator, alternator?
Name:	Photo Dec 29, 5 07 38 PM.jpg
Old 02-03-2014, 01:51 AM   #2
MarkyMark's Avatar
The first thing I would do is clean your battery and see if that helps. Power can be lost when you have corrosion or dirty terminals.
MarkyMark is offline   Reply With Quote
Old 02-03-2014, 01:56 AM   #3
It's not me, it's you.
primer2tone's Avatar
You could check the fluid level inside the battery. If you pop off the caps and you can see the plates, you'll need to add distilled water to it.
Here's an example of a battery low on water. The cell on the left is full, the two on the right are exposing the plates. It could cause low voltage problems.
Old 02-04-2014, 09:55 PM   #4
2 Stangz's Avatar
Region: Nevada
Got my 'stang back today, Ford ended up replacing just the battery, said the alternator was fine. No more flickering while motor is running so I guess it was just a bad battery.
Cleaned in back in September, it came back.
Attachment 146952
Did not know that - Thanks for the info. I'll keep it in mind for the future (unfortunately I read this post too late).
stock sound system vs. shaker audio system (2014 Mustang) Charlesph55 Mustang Audio & Video 6 02-15-2017 06:11 AM
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
For Sale: Pypes Pype-Bomb Super System 11-14 GT Boomer Mustang Parts for Sale and Wanted 6 08-24-2013 12:53 PM
Useful Mustang Information - READ THIS FIRST! Trojan Horse 1979-1995 Mustang GT 24 11-19-2012 09:54 PM
05:56 PM
