Adjustable shocks and struts - Mustang Evolution
Old 02-05-2014, 07:20 PM   #1
Vistablue's Avatar
Hey, anyone on here have adjustable shocks and struts?? Do you like them?? What springs are you running with them?? Thanks
Vistablue is offline   Reply With Quote
Old 02-08-2014, 12:28 PM   #2
Region: Oregon
Koni shock/struts with steeda springs are VERY popular from what i have seen/read.
Instafire is offline   Reply With Quote
Old 02-08-2014, 12:42 PM   #3
Stfmarc's Avatar
I use koni yellow and eibach pro kit perfect for street and track
Stfmarc is offline   Reply With Quote
Old 02-08-2014, 07:13 PM   #4
Can't report any experience yet but just received a set of Tokico D-Specs from AM. Shopping for mild drop springs too. After much research current thinking is Steeda Sports or Ultralights. Any other recommendations/ favs?
Will be following w/ interest.
Fasted58 is offline   Reply With Quote
Old 02-09-2014, 03:06 PM   #5
Vistablue's Avatar
Are the koni yellows adj.?
Old 02-09-2014, 03:37 PM   #6
Stfmarc's Avatar
Yes they are full ajustable
Old 02-09-2014, 04:19 PM   #7
Vistablue's Avatar
Do you drag or road course with them?
Old 02-10-2014, 04:24 PM   #8
Stfmarc's Avatar
Both
Old 02-10-2014, 05:08 PM   #9
Vistablue's Avatar
Does the adjustment work pretty well on the 1/4??
Old 02-12-2014, 02:31 PM   #10
lindertw's Avatar
strange single adjustable front struts/rear shocks with cobra jet "Q" springs on my '05 mustang. Set them to +5 or +6 for daily driving use, and I can adjust them at the drag strip as necessary. The setup works well for me...
2005 GT, N/A 302rwhp/317rwtq, 3500 lbs
12.095 @ 111.08, 1.576 60'
lindertw is offline   Reply With Quote
Old 02-12-2014, 07:51 PM   #11
Vistablue's Avatar
Sounds like a good set up man.
Old 02-12-2014, 08:13 PM   #12
Labrat's Avatar
I'm running Tokico D-Spec Adjustable Struts and Shocks with Elibach Pro Lowering Springs and they work just fine.
Labrat is offline   Reply With Quote
Old 02-13-2014, 01:16 PM   #13
Vistablue's Avatar
I also checked out those struts and shocks
Old 02-13-2014, 02:43 PM   #14
Labrat's Avatar
The Tokico 's are also very easy to adjust.
Old 02-13-2014, 05:57 PM   #15
Vistablue's Avatar
Yeah I hear they were.
Old 02-14-2014, 08:10 AM   #16
02NightmareGT's Avatar
What is the point of adjustable vs non adjustable?
02NightmareGT is offline   Reply With Quote
Old 02-14-2014, 09:38 AM   #17
Labrat's Avatar
You can adjust your ride comfort to a degree and your weight transfer!
Old 02-17-2014, 01:42 PM   #18
Send a message via AIM to Destination S19
The koni yellows are single adjustable, not double so they're not fully adjustable.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 02-17-2014, 03:34 PM   #19
Most people don't need the double adjustable if you're new to racing, however, I see it as if you do it do it right.
Arustik is offline   Reply With Quote
need advise on shocks and struts BAD CO. General Mustang Discussion 2 12-31-2013 12:01 PM
Aftermarket shocks & struts Gobabygo67 1996-2004 Mustang GT 3 02-09-2012 03:11 PM
Shocks and struts Justintriner 1996-2004 Mustang GT 2 12-12-2011 09:32 AM
Best shocks and struts for lowering? Blackedout Pre-2005 V6 Mustang 17 12-05-2011 07:57 AM
What shocks and struts should i use Kyle94GT302 1979-1995 Mustang GT 5 10-26-2011 12:09 AM
10:41 AM
