Gauge Resting Position - Mustang Evolution
Old 02-12-2014, 08:45 PM   #1
Kustumb's Avatar
Hey guys,
Would one of you be kind enough to post a picture of your 6-gauge instrument cluster with the needles at resting position?
I just replaced my base one on my V6 with a 6-gauge one with MyColor and am wondering where/how they should rest.
Thanks!
Kustumb is offline   Reply With Quote
Old 02-13-2014, 08:53 AM   #2
Dakota05's Avatar
Name:	ImageUploadedByMustang Evolution1392306774.584961.jpg
Hope this helps
Dakota05 is offline   Reply With Quote
Old 02-13-2014, 10:31 AM   #3
Kustumb's Avatar
Thanks man. Can you also post one with the engine on?
Old 02-14-2014, 08:53 AM   #4
Terminator's Avatar
With engine on some will vary on every car heat temp gas an idle
Terminator is offline   Reply With Quote
Old 02-14-2014, 10:32 AM   #5
Kustumb's Avatar
I'm just looking for where my oil pressure should be. Does it move when you guys drive around?
Old 02-14-2014, 11:01 AM   #6
Kustumb's Avatar
Old 02-14-2014, 04:06 PM   #7
Terminator's Avatar
Well my batter an oil have seem to be dummy gauges since I bought the car so I got aftermarket ones for those
Old 02-14-2014, 05:08 PM   #8
Kustumb's Avatar
Dummy gauges eh?
When I turn my car on, the needles move to just above middle.
I understand the battery shouldn't be moving any if at all, but I'm wondering if the oil pressure should be moving.
Mine stays steady whether I'm idle, just driving or wot.
Old 02-14-2014, 05:43 PM   #9
Kustumb's Avatar
Dummy gauges eh?
Old 02-15-2014, 01:41 PM   #10
Terminator's Avatar
Yea when you get aftermarket ones you will see difference
Old 02-15-2014, 03:37 PM   #11
Kustumb's Avatar
Yeah but is the pressure gauge supposed to be moving up and down noticeably as you drive?
Old 02-17-2014, 03:46 PM   #12
maverick214's Avatar
Yes a real oil gauge will.
maverick214 is offline   Reply With Quote
Old 02-17-2014, 03:48 PM   #13
Kustumb's Avatar
Ok so why isn't mine >.< what do I have to do
Old 02-17-2014, 04:19 PM   #14
Kustumb's Avatar
Ok so why isn't mine >.< what do I have to do??
Old 02-17-2014, 05:10 PM   #15
Because ours aren't real, they are like a dummy light. If its reading good pressure within the limits then it will go up to about half and sit there. It does not show you the actual oil pressure.
Old 02-17-2014, 05:13 PM   #16
Kustumb's Avatar
Hmm. Mine sits about 65% up, I'm sure it's good though, the car just got serviced.
Is there any way I could make it display the real pressure?
Old 02-17-2014, 05:23 PM   #17
Yes that's right.
Google 2005 mustang real oil gauge.
Old 02-17-2014, 05:35 PM   #18
Kustumb's Avatar
Are you just referring to me getting a seperate gauge pod?
Old 02-17-2014, 09:42 PM   #19
olds442111's Avatar
Send a message via AIM to olds442111
There was a big heated deal between the dealership and me on my F150 regarding this. On the truck, Ford had a resistor on the back side of the instrument panel which kept the gauge from pegging to " high" when the engine was started. The old days of a variable resistor as an oil pressure sending unit are gone. They use a switch, which was mentioned earlier, acts as nothing more than a light. When the engine starts, and the oil pressure goes above 7.5? pounds, the circuit is completed, and the gauge moves nicely to a little above halfway. The stink between the dealership and I got so heated, that a Ford rep ended up there, and they removed the resistor from the instrument cluster, replaced the sending unit with the old style, and the gauge then functioned as it should.
White 2014 GT Premium / Blower / Auto Trans / Louisiana
Blue 2016 Sport FX4 Crewcab / Blower coming soon
olds442111 is offline   Reply With Quote
Old 02-17-2014, 09:47 PM   #20
Kustumb's Avatar
Thanks for the update man but I don't think you'd know exactly how it was done right?
**** that's lame that we can't REALLY see the gauge working as it should.
Old 02-18-2014, 04:01 AM   #21
Screaming Mach's Avatar
I know I have a different year car then yours, but my oil gauge stays about 65% at all times and never moves, so I think your fine.
Screaming Mach is offline   Reply With Quote
Old 02-18-2014, 07:31 AM   #22
Wolverine0587's Avatar
I need to solder in my oil pressure and voltage gauges because for some reason my gauge pod doesn't have them. This is some good information.
Wolverine0587 is offline   Reply With Quote
Old 02-18-2014, 02:40 PM   #23
Kustumb's Avatar
Solder what to what exactly? And were talking about the gauges that are IN the instrument cluster
Old 02-18-2014, 02:54 PM   #24
The stepper motors that move the guages. There are sockets for the two I mentioned, just none in there from the factory. Since I have some stepper motors I've been planning to install I will need this picture for when I acquire the needles that go on them... And also a new face insert.
2005 gt cluster gauge repair... jmpark527 2005-2010 Mustang GT 29 11-25-2015 09:05 AM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Looking for a good AFR gauge CrimsonGT 1996-2004 Mustang GT 5 01-26-2013 10:23 PM
calibrate wideband gauge dreamstang 1979-1995 Mustang GT 15 08-11-2012 08:37 PM
20 gauge to 18 gauge XXSTEVEO66 General Mustang Discussion 0 08-16-2011 06:58 PM
07:39 PM
