Check Charging System - Mustang Evolution
Old 02-14-2014, 12:12 PM   #1
I have a 2009 Candy Apple Red Mustang GT- I have a Check Charging System Light on. I took the Mustang to Auto Zone and checked the Chargin System and the Battery which both checked out ok. I did notice there was some corrosion on the negative battery terminal. I will clean the terminals and disconnect that negative and positve terminal and grease it. If that does not clear the code what is the next step?
rpstrickland is offline   Reply With Quote
Old 02-14-2014, 12:23 PM   #2
If all of that doesn't work, your next step will be to go somewhere better than Auto Zone to have your charging system diagnosed...
Old 02-14-2014, 12:42 PM   #3
Check Checking System
My first concern was either the Battery or the Altenator however with only 48K miles I did not suspect the Altenator. The battery was replaced in MAY OF 2012 under warranty it is a factory Ford Battery so it is about 18 months old.
Charging systems are not complex if the altenator is charging at the voltage as required and the battery is good I am thinking it is a stuck code. The code flashed on a very cold night here in Texas and with the contact not being 100% it could be pretty simple.
Old 02-14-2014, 12:49 PM   #4
Hopefully when you clean everything up and clear the codes, it won't come back.
Carefully inspect the cables and make sure that you have good tight ground connections as well.
I presume that you haven't been experiencing any problems aside from the light being on?
Old 02-14-2014, 01:01 PM   #5
Stfmarc's Avatar
Most of the time its the alternator
Stfmarc is offline   Reply With Quote
Old 02-18-2014, 06:06 AM   #6
Checking Charging System
I cleaned the negative battery terminal code still remains. The altenator is charging at 14.6 and the battery still checks good. Ugh...
I have had no problems other than the light the car only has 48K miles on it.
Old 02-18-2014, 11:20 AM   #7
Did you try clearing the code and see if it comes back?
Arustik is offline   Reply With Quote
Old 02-18-2014, 11:21 AM   #8
Charging System
How do you clear the code?
Old 02-18-2014, 11:22 AM   #9
Your local autozone or any gas station with a garage could do it for you usually free of charge.
Old 02-18-2014, 11:49 AM   #10
Just disconnect the battery for about 20 minutes. That wll clear the codes.
Old 02-18-2014, 11:50 AM   #11
Or that I guess.
Old 02-18-2014, 01:30 PM   #12
Thanks I will try that tonight after work.
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
Louder Sound Idea!! MustacheMustang 2011-2014 V6 Mustang 196 05-19-2013 02:21 PM
For Sale: (11-14) Flowmaster American Thunder Cat-Back Exhaust System DWC_SmOziLLa Mustang Parts for Sale and Wanted 25 04-21-2013 11:50 AM
03 fuel rail Xaperez100 1996-2004 Mustang GT 3 04-12-2013 02:52 PM
'88 GT check engine light? robert81717 1979-1995 Mustang GT 7 07-12-2011 11:56 PM
10:29 PM
