Ford racing springs - Mustang Evolution
Old 02-14-2014, 02:44 PM   #1
Hfdbuck09's Avatar
Ford racing springs
The ford racing springs that say they only lower an inch will i need anything else? Ive read and read about all the lowering thats 1.5 and lower and say you have to have a bunch of other stuff to make everything right and functional but i havent read anything about just an inch all the way around
Hfdbuck09 is offline   Reply With Quote
Old 02-15-2014, 02:16 AM   #2
Region: Oregon
an adj. panhard bar might be the only thing you really need.
Instafire is offline   Reply With Quote
Old 02-17-2014, 05:26 AM   #3
Hfdbuck09's Avatar
Thanks for the reply. Is this the only answer, is it correct, need more? Not looking to setup for track just a stance but want it done right just need to piece it together and need to know what i can get away with at first
Old 02-17-2014, 01:34 PM   #4
Send a message via AIM to Destination S19
If you're just getting the FRPP P springs with only lower it 1", you should only need an adjustable panhard bar (do NOT get the aluminum J&M bar) and aftermarket shocks to replace the factory ones which are not valved to be used with a lowered stance. Get a set of Koni STR.T (orange) and the P springs with an adjustable steel panhard bar, and the GT500 strut mounts (reusing the factory mounds can lead to failing of the bearings and popping noises). If you were wanting to be safe, you could get adjustable camber plates if the factory tolerances for the factory camber don't allow you to get aligned properly. The tolerance for factory camber is .7 to -.7 degrees I believe so its possible you can't get back into factory spec with GT500 plates after lowering, most likely you'll be fine but its a possibility.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 02-17-2014, 03:23 PM   #5
Agreed. If you want to get shocks to go along with your springs then get a set of Konis
Arustik is offline   Reply With Quote
Old 02-17-2014, 03:37 PM   #6
Hfdbuck09's Avatar
That sounds good. Ill start shopping around and see what i can come up with. Thanks for the replies and info
Old 02-18-2014, 03:09 PM   #7
Hfdbuck09's Avatar
Found a good deal on oem gt500 shocks, struts, strut mounts, and springs. Is there a heigth diff in factory gt and gt500 suspension?
Old 02-18-2014, 10:04 PM   #8
The GT500 stuff isn't any better than the stock GT stuff really. Just order Koni Oranges, your choice of springs (FRPP P springs) like you wanted and grab an adjustable panhard bar and GT500 strut mounts.
Old 02-19-2014, 06:19 AM   #9
Hfdbuck09's Avatar
Ok. Sounds good. Wasnt sure if there was much of a diff.
Ford Racing springs for GT500 advice GT500 Fan Shelby Mustang 2 03-07-2014 03:48 PM
Ford racing tune Cise General Mustang Discussion 2 01-16-2014 09:50 AM
White Smoke from under my 2012 V6 Cool Shadow 2011-2014 V6 Mustang 63 09-27-2013 01:59 AM
Eibach vs ford racing?? McQueen 2011-2014 Mustang GT 24 09-17-2012 11:33 AM
ford racing B&E 303 cams C4king General Car Discussion 0 07-26-2011 10:11 PM
04:07 PM
