Gas pedal hard - Mustang Evolution
Old 02-16-2014, 02:43 PM   #1
Kstangs2002's Avatar
Gas pedal hard
Installed bbk cai and bbk 75mm throttle body and plenum and brand new intake manifold and for sum reason my gas pedal is hard just at the begining i have to push hard thats everytime i take my foot off the gas i checked it while the car is off and its soft regular is this normal or what should i check for
Kstangs2002 is offline   Reply With Quote
Old 02-16-2014, 03:00 PM   #2
The vacuum that the engine is producing while it's running is holding the butterflies closed making the throttle feel sticky until you break the seal.
If you search cliffyk's posts, he explains, or posts a link, how to properly adjust a throttle body.
Old 02-16-2014, 04:08 PM   #3
Kool thanks
Old 02-17-2014, 01:40 PM   #4
Send a message via AIM to Destination S19
Well since this is 05-09 tech, a sticky gas pedal is unrelated to the butterflies on the TB since the S197 throttle control is electronic (there is no cable connection between the TB and gas pedal). Unless I missed what kind of car you have.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 02-17-2014, 01:47 PM   #5
Yes.
You did.
He has an '02...
Old 02-17-2014, 02:07 PM   #6
Originally Posted by straybullitt View Post
Yes.
You did.
He has an '02...
I figured as much from the TB size since the only upgrades for GTs are twin 62mm from the factory dual 57mm. Still wrong section
Old 02-17-2014, 03:26 PM   #7
+1 ^^ wrong section
Arustik is offline   Reply With Quote
Old 02-17-2014, 03:34 PM   #8
Nobody's perfect.
We try to provide fast, friendly service here at ME... No.matter which forum that you post in.
Old 02-18-2014, 12:45 AM   #9
Ooops just noticed that thanks guys and cliffs tread was right on it and fixed it
Gas pedal l2plagears Pre-2005 V6 Mustang 8 02-12-2012 10:54 AM
93 octane gas in phoenix? angelofrat42 2005-2010 V6 Mustang 0 02-07-2012 06:02 PM
gas leak Berbantor 1996-2004 Mustang GT 2 02-05-2012 07:59 PM
Best Gas to use and any additives? Spiney SVT Mustang 5 12-23-2011 05:35 AM
hard to shift into 3rd vinnygt 1996-2004 Mustang GT 6 06-24-2011 02:31 PM
09:20 PM
