what tire will fit? - Mustang Evolution
Old 02-21-2014, 05:26 AM   #1
08mustanggt's Avatar
what tire will fit?
Probably answered a million times but what is the largest tire I can fit on the back? Im look ing to get a set of 15 x 10.5 darkstars with a big drag radial for my turboed 08 gt. Thanks guys and gals!
08mustanggt is offline   Reply With Quote
Old 02-21-2014, 08:45 AM   #2
Send a message via AIM to Destination S19
A 15 x 8 is the widest wheel you can you put on the rear without modifying the rear sway bar brackets and it's location. The tire width will depend on the backspacing and offset of the wheel to allow for clearance of the shocks.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 02-21-2014, 06:16 PM   #3
This isn't true because I currently run a 10 in the rear
Old 02-21-2014, 07:56 PM   #4
C_Dailey95's Avatar
Try willtheyfit.com. But my guess is around 305
C_Dailey95 is offline   Reply With Quote
Old 02-21-2014, 08:00 PM   #5
I was thinking around 305. Hope so!
Old 02-22-2014, 04:50 PM   #6
Then you must be mistaken and are running a 17x10 since a 15x10 requires modifying the sway bar brackets. Its a well known fact on these cars. If you bought the car like it is, they were modified before by the previous owner.
Also, a 305 may not fit if your back spacing isn't far enough out.
Old 02-22-2014, 05:34 PM   #7
C_Dailey95's Avatar
I think you're mistaken. You can run a 10 with 48 offset no problem. Hence why American muscle sells 18x10 +45-48 rear offsets. You can shove a lot of meat under our cars. I know a guy running 18x11 +22 all around with a 305 out back and 275 up front. I have a 18x9.5 275/40 all around. Fits just fine.
Old 02-22-2014, 07:15 PM   #8
I didn't say an 18 wouldn't fit, I said 15...
The wheel diameter is too small to fit over the sway bar bracket.
Old 02-23-2014, 01:05 PM   #9
Im running 18x10
Old 02-23-2014, 01:20 PM   #10
Im running 18x10
You should be good to run a 305 or maybe even a 315 depending on tire manufacturer. Some of them narrow and some wider. Nittos tend to run narrow than others so a 305 nitto may only be a 10 or 10.5 inch tire whereas a 305 in Hankook could be an 11. Most of them have the tire specs on their websites so it's best to check there to wheel fitment recommendations. What you can fit on a wheel and what works best aren't always the same thing.
Nitto NT05R
P305/45R18 LL Tread Depth - 6.3 Tire Height - 28.90 Overall Width (in)- 12.05 Wheel sizes recommended. 9.5-(10.0)-11.5
Old 02-23-2014, 02:41 PM   #11
Venomouz831's Avatar
You can get away with a 315 on a 10'. I've done it before with some pirellisClick image for larger version
Name:	ImageUploadedByMustang Evolution1393191671.979658.jpg
)02 Gt, Founder of WE2G
NMRA "Super 'Stang" rules and regulations rebeltx At the Track 4 03-06-2013 11:02 AM
tire question mattthegreat210 Mustang Wheels & Tires 15 11-03-2012 06:48 PM
Widest tire you can fit on a 2012 GT SkoSter06 2011-2014 Mustang GT 36 12-03-2011 07:42 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
03:36 PM
