Knock sensor - Mustang Evolution
Old 02-22-2014, 11:31 AM   #1
theweekday's Avatar
Knock sensor
I got a code for knock sensor that just popped up, can some tell what is the knock sensor for exactly?
theweekday is offline   Reply With Quote
Old 02-25-2014, 01:50 PM   #2
theweekday's Avatar
Bump
Old 02-25-2014, 02:44 PM   #3
pilatti1's Avatar
My wife had the same issue with her yukon. From what I am told it senses knock in the engine usually from bad or low quality gas. I used Royal Purple fuel cleaner and the issue went away. You can try 91-93 octane first
pilatti1 is offline   Reply With Quote
Old 02-25-2014, 03:01 PM   #4
theweekday's Avatar
Sounds right. I did a full tune up yesterday and the fuel filter looked like coke coming out
Old 02-25-2014, 07:06 PM   #5
pilatti1's Avatar
I like to use the RP every once and a while as I think it helps keep things clean & running good, it also improved my mpg
Old 02-25-2014, 07:27 PM   #6
theweekday's Avatar
Ima go snag a bottle. But the knock sensor shouldn't hurt anything will it?
Old 02-25-2014, 07:54 PM   #7
pilatti1's Avatar
it should be fine just good gas & RP should do the trick & then the Check Engine light should go off
Old 02-25-2014, 08:10 PM   #8
theweekday's Avatar
HELP!! P0141 Code Adl_s07 1996-2004 Mustang GT 8 11-14-2013 03:52 PM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 05:33 PM
Running better on 91octane monkey13 2011-2014 V6 Mustang 45 02-10-2013 01:27 PM
Oxygen sensor help! mhobbs 1996-2004 Mustang GT 0 01-22-2012 02:36 PM
Does foxbodys have a knock sensor? Stang.racr 1979-1995 Mustang GT 8 07-20-2011 04:28 PM
08:51 PM
