'05 GT sway bar bushings and end links - Mustang Evolution
Old 03-01-2014, 01:53 AM   #1
Lowering a '05 GT DD w/ Steeda Sports (1.0/1.25), D-Specs, BMR adj. greasable poly PHB etc. While I'm in there I'll address the stock sway bar bushings and front end links. Kind of set at this point on Prothane bushings vs. OEM style rubber... reviews are mixed for a DD w/ poly, squeaking being an issue. Either way they'll be replaced w/ 48K miles on the chassis. What would be the preferred bushing choice here w/o excessive maintenance? Also, going to replace the front bar links. Will OEM style be acceptable w/ a 1" drop or aftermarket? Steeda has an adjustable ball and socket type that sounds promising. Not thinking heim ends on this DD. TIA
Fasted58 is offline   Reply With Quote
Old 03-01-2014, 11:49 AM   #2
Silver06GT's Avatar
The Steeda sway bars I put on last spring came with poly bushings and I haven't had a problem with them (just make sure you grease them when you install them). With a 1" drop you should be fine with OEM style end links. If your not going to go to take it to road courses I wouldn't worry too much about adjustable end links.
Silver06GT is offline   Reply With Quote
Old 03-03-2014, 04:40 PM   #3
garbill2003's Avatar
Camber bolt with your drop will help alot
garbill2003 is offline   Reply With Quote
11:39 PM
