Need advice!! - Mustang Evolution
Old 03-01-2014, 04:41 PM   #1
Need advice!!
Hey everyone, I have a 2007 mustang gt. Currently it has a cai, 62mm throttle body, shorty headers with an off road x-pipe exhaust, stage 2 clutch, slotted and drilled rotors, and I have a tuner and have tuned her. Does anyone have any suggestions for what else I could do to her for performance upgrades that won't totally drain my bank account? My ultimate goal is to turbocharge her, but is there anything relatively inexpensive I could do to her for some added horsepower?
cgibbs7 is offline   Reply With Quote
Old 03-01-2014, 04:43 PM   #2
Rapinator126's Avatar
Hot rod cams. Motion delete plates. Ford racing intake mani. Nitrous
Old 03-01-2014, 06:45 PM   #3
What would be the best nitrous set up to get? And would I need to mod anything else to do it? And I'm thinking about buying the intake manifold
Old 03-01-2014, 07:15 PM   #4
Get the plate kit from nitrous express. A window switch, purge, bottle heater and a good tune
Old 03-01-2014, 07:16 PM   #5
Wet system is better right?
Old 03-01-2014, 07:27 PM   #6
Yes
Old 03-01-2014, 07:28 PM   #7
How much do you think the kit will cost? And all of my friends keep sayin I'm gonna mess up my engine. Is slotted and drilled rotors all I need to be able to support the extra pressure?
Old 03-01-2014, 08:25 PM   #8
$1,000-1,200 for kit. Window switch. Bottle heater purge. Then say $400-500 for. Tune. Ad long as you get a good tune and just run a 100 shot you will be fine
Your stock breaks will be fine bud.
---------- Post added at 09:25 PM ---------- Previous post was at 09:24 PM ----------
* brakes.
Old 03-01-2014, 08:26 PM   #9
Thanks for all your help. I appreciate it. Now just to wait so I have enough money...
Old 03-02-2014, 02:45 PM   #10
08StreetBeast's Avatar
I would do cams before anything else at this point. A better set of cams would unlock a bit more power and they aren't too expensive.
08StreetBeast is offline   Reply With Quote
Old 03-02-2014, 02:59 PM   #11
Not true. Nitrous would be the best bet. If he did go cams he would have to spend more money later on. If he goes turbo like he said.
Old 03-02-2014, 03:10 PM   #12
Eturner's Avatar
For the same price I would do Cams before Nitrous!..
Old 03-02-2014, 03:12 PM   #13
Hr said he wanted a turbo. SO later on he would have to pull whatever cams he did to go turbo. SO would cost more money. Go nitrous. To many people who do NOT have a clue on what they are talking about
Old 03-02-2014, 04:01 PM   #14
Eturner's Avatar
Not really true!.. Know a few guys that have Stage 2Cams from Comp that are also FI!.. And I'm not talking about the cams made specifically for turbos etc!.. Yes if your looking to build a Track Machine, then you'll need the other cams!.. But if your looking for something that is treatable then no!.. Been researching it myself as I was going to add Cams this time around but decided not too!.. I'm also planning a Turbo in the near future!..
Old 03-02-2014, 04:23 PM   #15
Hey buddy. A NA CAM will cause you to loose power with a turbo and so will a blower CAM. SO do some more research.
Old 03-02-2014, 05:06 PM   #16
Eturner's Avatar
Are you sure........ Hahahahahaha. Explain why someone can simple add a turbo then to an otherwise stock car and not lose any power!..
Old 03-02-2014, 05:34 PM   #17
Bc of the exhaust duration and overlap on a NA CAM or blower CAM will not be up to specs for a turbo aplication. Never said anything about stock cam did i?
Dont be max bc your shot is slow hagan
Old 03-03-2014, 12:20 PM   #18
Also, this is a little off topic, but my upholstery on my doors is starting to come off at the bottom. What is the best way to reattach it? I bought some fabric glue and some rubber paste but I wanted to check with y'all before I tried anything
Old 03-06-2014, 07:24 PM   #19
I believe the ford racing intake manifold comes with the delete plates built in.
little rick is offline   Reply With Quote
Old 03-06-2014, 08:06 PM   #20
Maybe Idk. Back When I had a 3 v i had a blower so I never purchased the maní.
208k 1999 Cobra Purchased, Need Advice!! 1999Cobra General Mustang Discussion 27 02-28-2014 09:01 AM
need advice rod Classic Mustangs 2 03-30-2012 10:15 AM
exhaust advice Beau 2005-2010 V6 Mustang 4 12-20-2011 06:13 AM
My Side Mirror Broke Off and Now I Need Advice Regarding Replacement JimHyde 1996-2004 Mustang GT 3 12-03-2011 08:16 PM
Advice 89white GT General Car Discussion 11 08-17-2011 03:38 PM
01:14 AM
