Down pipes + Axelback - Mustang Evolution
Old 03-04-2014, 05:10 PM   #1
Does an aftermarket axelback(SLP) fits with an aftermarket x pipe without changing the exhaust pipe over the axels??
I heard that X-H pipes fit perfectly into catbacks, but I have no idea if down pipes fit with axelback perfectly.
Anyone??
joseph197 is offline   Reply With Quote
Old 03-05-2014, 08:49 AM   #2
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Anyone??
Hey,
Good question, this is a common problem a lot of people run into when building their S197s.
The aftermarket mid pipe will be a direct fit replacement for your existing mid pipe, and the aftermarket axle back will be a direct fit replacement for your current mufflers. With this being said you will be able to bolt both of these to the over axle portion with no problems as far as fitment goes.
However, as far as flow rates go you will have a free flowing mid pipe, going into a constrictive factory over axle section. This set up will be functional, and still give you horsepower gains, but it is not the ideal set up. Ideally you want the exhaust to flow as freely as possible from header to tailpipe. This will produces the best flow rates and give you the most power gains.
I hope this helps, and if you have any other questions, feel free to ask myself or contact our customer service team listed below my signature. Good luck!
-Dan
Old 03-05-2014, 12:27 PM   #3
Thank you.
What if I want to get the maximum air flow? How to obtain it? Do I have to change the over axle portion?
Again, thank you for your time sir.
Old 03-05-2014, 01:41 PM   #4
AmericanMuscle.com
Sponsor
Thank you.
Not a problem at all, that is why we are here.
If I'm assuming properly, it sounds that you already have an axle back system and want to get a mid pipe in the near future. If that is the case, then yes, to achieve the best results, you would want to get the mid pipe and the over axle piping.
The over axle pipes can sometimes be hard to come by, though. So what a lot of people wind up doing is getting a cat-back system, and sell either their used system, or sell the axle back portion of whatever system they buy.
If you go directly through some of the manufacturers, they are usually happy to sell you just the over axle pipes. If my assumption is correct, this is probably the easiest and most logical solution in your case.
I hope this helps, and if you have any other questions don't hesitate to let me know. Good luck!
-Dan
Old 03-05-2014, 02:11 PM   #5
Thanks a lot Dan..and yea I've got an SLP axelback looking forward for a corsa X pipe...thanks a lot for the help.
-Joseph
Down pipes + Axelback joseph197 2005-2010 Mustang GT 0 03-04-2014 04:32 PM
SLP race pipes... leviz79 1996-2004 Mustang GT 0 01-04-2012 12:47 AM
Flamethrower from tail pipes shsfresh87 General Mustang Discussion 8 12-14-2011 05:01 AM
Will 96 cobra pipes. Fit my 2003 v6 Bama blazer Pre-2005 V6 Mustang 3 12-04-2011 08:35 PM
05:30 PM
