Installed cai - Mustang Evolution
Old 03-07-2014, 03:00 PM   #1
BadAssStang07's Avatar
Installed cai
Hey I installed a jlt cai series 3 on my 07 gt, install was easy but after I tuned her the car is getting a check engine light saying its running to lean, I know that's not good and I really need some help with that so if any one knows the problem please tell me.
Sent from my XT1080 using Mustang Evolution mobile app
BadAssStang07 is offline   Reply With Quote
Old 03-07-2014, 03:14 PM   #2
Need some help guys before I put the stock box on
Old 03-07-2014, 05:53 PM   #3
maverick214's Avatar
Double check all your connections to the cai. If they are all good then have them double check your tune. I got a bad email tune one time, the guy forgot to change it for my cai.
Is this the first time with a tune?
If your tuner has some built in tunes for your cai could try them and see if it's lean. If so then something is not right with the cai.
maverick214 is offline   Reply With Quote
Old 03-07-2014, 09:45 PM   #4
Aggiesrok's Avatar
Really check the connection at the throttle body. I had a leak there and it threw a code.
Old 03-08-2014, 05:38 AM   #5
I checked every connection there is, unless I'm blind there isn't one. I took it back apart and reassembled it and I drove it for a while and no check engine light, thought that was a good thing but then my car was running horrible. I think that cai is a bad part and I'm sending it back to get my money back
Old 03-08-2014, 06:03 AM   #6
BaSohol's Avatar
If your 100% sure you got everything correct I would suspect the tune to be wrong, I have the jlt 3 no problem
Check the throttle body connections, and don't tighten the adapter to CAI to much
Make sure you have the tube from the passenger side cam cover installed
Make sure the MAF is facing the right direction, and clean it with MAF cleaner, you could of got it dirty from improper handling of it or oil from the filter
2007 Ford Mustang GT 5spd
Old 03-08-2014, 08:34 AM   #7
Did you get a tune with it? Mine did that until I loaded a tune.
little rick is offline   Reply With Quote
Old 03-08-2014, 09:09 AM   #8
Yeah I have a custom tune for the jlt intake, I even tried the 93 octane tune but then my car would crank And the rpms dropped all the way down making it cut off everytim e
cai
FS steeda cai for 11+ GrabberBlue5.0 Mustang Parts for Sale and Wanted 14 01-03-2013 06:36 PM
AM ... Is custom tune needed after having new 3.73 installed today! SCCofSV 2005-2010 V6 Mustang 1 01-03-2013 10:24 AM
Another cai and tune ? Stang.racr 2005-2010 Mustang GT 10 01-01-2012 07:49 PM
roush cai vs jlt/steeda cai godsdisciple85 General Mustang Discussion 0 09-20-2011 08:34 AM
Best CAI?? 11stangGT 2011-2014 Mustang GT 29 07-17-2011 12:16 PM
03:25 PM
