Shifting problem - Mustang Evolution
Old 03-07-2014, 09:21 PM   #1
mattthegreat's Avatar
Shifting problem
I have a 2007 gt 5speed manual its stock I took it to the track today and it giving me problems! Wen im in second gear and it gets to about 5000 rpms wayy before I would shift it feels like it kills the power and I look stupid ha its done it 4 times already and I can't get a good run time! Amy ideas?
Sent from my SPH-L710 using Mustang Evolution mobile app
mattthegreat is offline   Reply With Quote
Old 03-07-2014, 11:33 PM   #2
kila07GT's Avatar
Im thinking the culprit could be a faulty injector. Sounds like not enough fuel is being added to the air at high rpms. You may not notice the problem during normal driving since you dont reach those high revs on street roads. Check and replace your fuel filter, check air filter since it could be bottlenecking the air flow. If that doesnt work you will need to clean your fuel system and get injectors serviced or replaced. Hope this helps.
kila07GT is offline   Reply With Quote
Old 03-07-2014, 11:53 PM   #3
That makes sense but wouldn't it do that before shifting to 2nd gear? Kuz wen im in first gear I can red line it and it won't do the same thing? And thanks I will check those things out tomorrow morning!
Old 03-08-2014, 07:14 AM   #4
Count Dragula's Avatar
Cops maybe? I replaced mine on my old car and it was doing the same thing...
Sent from my SCH-I605 using Mustang Evolution mobile app
---------- Post added at 09:14 AM ---------- Previous post was at 09:14 AM ----------
Does it do anything when you put the engine under a load?
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 03-08-2014, 09:31 AM   #5
Cops?? And no just that its really weird
Old 03-08-2014, 09:40 AM   #6
Coil on plugs.
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 03-08-2014, 09:42 AM   #7
Coil on plugs.
Ohhh I need to replace em?
Old 03-08-2014, 10:41 AM   #8
I'm not sure. They can do tricky things.. they aren't cheap either
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 03-08-2014, 10:48 AM   #9
Is it possible its just some kind of rev limiter? Kuz its consistently at 5k rpms
Old 03-08-2014, 12:55 PM   #10
Nah the rev limiter doesn't change in each gear
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 03-09-2014, 03:14 AM   #11
Belt slip?
Old 03-09-2014, 12:25 PM   #12
kila07GT's Avatar
Yes its strange that it lets you redline in first but hold back on second. Does it do this on gears after second as well? Im guessing whats happening is the engine is going into a safe mode of sorts to prevent you from damaging it. This could also be a tune related scenario. Did the previous or you put a tune on the car? If its no to all the above then you would have to do all the preliminary checks we suggested and yes COPS is a something you should look into as well. If you could take a to a dearlership or Mustang speed shop im sure the mechanica there could narrow it down for ya and save you alot of money trying to individually diagnose and replace these parts.
Old 03-11-2014, 08:33 PM   #13
I don't think it has a tune but it does it in 3rd also
Old 03-12-2014, 05:49 AM   #14
Reason I think it is cops is the load on the engine is greater after first gear. I'm no expert but that's what mine did. Put it in 5th at about 30 to 35 mph going up a hill and floor it. Then let me know what it does
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 03-12-2014, 06:07 AM   #15
Ok I will try that! Thanks! It only has 24k on it I didn't think anything should be happening yet! Ha :/
Old 03-23-2014, 07:38 AM   #16
Now it does it in 1st
Old 03-23-2014, 11:58 AM   #17
I think your coils are shot. Just my guess
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 03-23-2014, 07:35 PM   #18
G3ARH3AD's Avatar
Yea def sounds like a cylinder misfire now weather it is an injector or plug & coil and if its 1 or many, u can use a scan tool and check mode 6 data and view misfire counts but most cheaper scan tools cant view that, snap on scanner or ids at dealerships can though for sure
G3ARH3AD is offline   Reply With Quote
Old 03-24-2014, 09:00 PM   #19
I'm thinking it would be just one. When one of mine went bad you could barely tell but when multiple when bad you could barely drive the car
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-10-2014, 10:54 PM   #20
It drives normal but wen Im pushing it shift real hard to make the tires chirp it just feels like I let off the gas completely and wen I feather the gas pedal it will barely respond for a sec or 2 then its good till the next time I shift but it won't do any of that wen I granny shift
Old 04-11-2014, 07:16 AM   #21
Send a message via AIM to Borii
I agree it coudl be a coil. Injector also. If it runs too lean it will cut causing your issue. It is a saftey measure. Don't keep trying until you figure it out.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 04-30-2014, 05:47 AM   #22
I figured out y it was running lean and fixed it and I changed them to accel coil packs still same situation :/
Old 05-03-2014, 04:37 AM   #23
When you change the coils you want to go with OEM. Nothing else seems to be nearly as good.
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 05-03-2014, 04:57 AM   #24
Hulk 5.0's Avatar
Sorry to hear that, you should definetly take it to get diagnosed. Not on my stang, but on my old STi I had a similar problem and that was s ROYAL PITA to get it right! It came dowm to whem I installed the new spark plugs I didnt check the gap. We went back to basics verifyng everything till we got to the spark plugs and when we checked the gaps it was way off. Got em right and 2 years later till the day I traded her no problem. Hope this helps.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Gotta Have It Green GT 2013 | Recaro | Brembo | Track | 3.73 Rear End | Boss 302 Intake Manifold -Dynatech Long Tube Headers - Magnaflow Full Exhaust & Tru X Pipe 3 - JLT Intake- SCT 91 Tune - BMR Pan Hard Bar - SR Performance Sway Bar Kit - Steeda Strut Bar - MGW Shifter Kit - Hankook RS3 275 Rear - Hawk HPS Brake Pads - Roush Front Lip & Roush Full Side Skirts
Hulk 5.0 is offline   Reply With Quote
Old 05-03-2014, 12:50 PM   #25
Originally Posted by Hulk 5.0 View Post
Sorry to hear that, you should definetly take it to get diagnosed. Not on my stang, but on my old STi I had a similar problem and that was s ROYAL PITA to get it right! It came dowm to whem I installed the new spark plugs I didnt check the gap. We then started back to basics verifyng everything till we got to the spark plugs and when we checked the gaps it was way off. That fixed it for me. Hope this helps.
Thanks hulk! I'll check them asap!
Black headlight covers problem GTstang07 2005-2010 Mustang GT 22 01-11-2012 11:29 PM
95 cobra start problem jhagan1980 SVT Mustang 1 01-06-2012 04:51 PM
Cut out problem 89white GT 1979-1995 Mustang GT 3 01-05-2012 05:48 AM
Clutch problem 96 stang 1979-1995 Mustang GT 4 09-14-2011 10:38 PM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
04:28 AM
