Rear End Height - Mustang Evolution
Old 03-22-2014, 11:15 PM   #1
Rear End Height
I just noticed today that the rear driver side on my 07 GT is lower than the passenger side. I noticed the gap between the tires and the fender is wider on the passenger side. My neighbor suggested that since the gas tank was on the driver's side the weight was making that side lower, making the gap less wide. I inspected the suspension and everything looked okay, and yes I measured the spacing on a leveled surfaced. Any suggestions, or have any of you ever experienced this? Any feedback is appreciated.
tonyjuan is offline   Reply With Quote
Old 03-23-2014, 02:49 AM   #2
SixBanger's Avatar
I can tell you that it's not the gas tank because it's centered between the rear wheels. Seems like a suspension problem to me. I'm not a suspension guy myself, but I can tell you that's most likely the issue. Something on the lower side is worn out (be it the shock or spring).
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 03-23-2014, 03:48 AM   #3
Tyoung68's Avatar
Could be bushings also
Old 03-23-2014, 06:40 AM   #4
stemar's Avatar
This is normal for our cars the fuel tank is devided so to speak and fuel is pulled from the passenger side first so as the fuel level in the tank lowers the tire to fender gap will change check your gap with a FULL tank once. My car has the same gap issue when mt tank is not full and I have new lowering springs struts/shocks
Pypes shorties, BBK catted X, Flowmaster Pro's, K&N CAI, FRPP- P springs, Steeda UCA, J&M Panhard bar, Hurst Comp plus, FR500 Wheels W/NITTO's , SCT SF3 W/BAMA 93 Race tune, Pioneer TS-D6802R speakers, chin spoiler, Eleanor style grill, GT500 rear spoiler
stemar is offline   Reply With Quote
Old 03-23-2014, 10:27 AM   #5
I'll fill the tank today and see what happens. I'll be checking everything as I go.
Thanks for the suggestions.
Old 03-31-2014, 02:16 PM   #6
maverick214's Avatar
Mines the same way, I even swapped the springs one day. Same.
Just doesn't look right.
Mine hardly has any gas in it and it's still lower on one side.
Maybe it's the rubber mount?
maverick214 is offline   Reply With Quote
Old 03-31-2014, 04:02 PM   #7
Car height
Hey Maverik214, which side is lower on your car? I wonder if this is a common problem, and what causes it. I hear what Stemar says, but I find it hard to believe that is common, so let's hear from more people and hopefully we get to the bottom of this problem.
Thanks guys.
Old 03-31-2014, 09:32 PM   #8
kila07GT's Avatar
Check your tire pressure.
kila07GT is offline   Reply With Quote
Old 03-31-2014, 10:02 PM   #9
FullyAutomatic's Avatar
Region: Mexico
probably not parked on flat surface
FullyAutomatic is offline   Reply With Quote
Old 04-03-2014, 04:40 PM   #10
Drivers side is 1/2" lower.
Tire pressure same, level surface.
Got to be the spring mounts, or bad shock. Mine is lowered, stock shocks.
I posted this before and there is quite a few people who had this too.
Old 04-04-2014, 04:43 AM   #11
stemar's Avatar
The only thing I can say is the information I gave about the fuel in tank level came from information I got off of another Forum talking about this same issue. I never even took notice of the gap until I lowered my car and installed 1" wheel spacers witch pushed the wheels out to the edge of the fenders I also pulled the rear springs back out swapped them from side to side did everything short of pulling the rear out of my car I have NEW FRPP-P springs new struts / shocks /new strut mounts ect. My car only has 25K miles on it and never in an accident and sits in my garage and only comes out in nice weather so at this point I have to assume its a ford design thing unless someone can tell me otherwise
Old 04-04-2014, 09:19 AM   #12
Aggiesrok's Avatar
If its fuel tank related then measure when it's on E, it should make a difference. Also, do you have an adjustable panhard bar or at least measure that. If its shifted to the left, it could change the weight distribution on the suspension some.
Old 04-04-2014, 09:23 AM   #13
audioAl's Avatar
Do you have an adjustable panhard bar? May need to re-center the rear.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 04-09-2014, 09:49 AM   #14
Send a message via AIM to Borii
Agreed. If the axle is shifted to one side, then the other side rear will be lower.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
stock height?!? carlosc Pre-2005 V6 Mustang 2 01-21-2009 07:27 AM
Scooter + Car = Good Height and Rotation PureVenom Pictures and Videos 12 10-27-2008 10:31 AM
Basketball Star Wannabe Sues Over Height sctalbott The Bar 11 10-10-2004 09:21 AM
05:58 PM
