Leaking water on passenger side! - Mustang Evolution
Old 03-25-2014, 07:52 AM   #1
Cam Capollo's Avatar
Every time it rains, water starts leaking on the inside! I heard someone say it may be a drain dats clogged up.. Anyone know wut dats about?
Cam Capollo is offline   Reply With Quote
Old 03-25-2014, 09:26 AM   #2
G3ARH3AD's Avatar
Could b a floor drain, door drain, bad weather striping on the door seal as well, possibly even the rear quarter window or windshield also
G3ARH3AD is offline   Reply With Quote
Old 03-25-2014, 09:29 AM   #3
It comes from under da dashboard.
Old 03-25-2014, 09:32 AM   #4
jellyroll's Avatar
Pop the cowl cover off the passenger's side and take a look at the drain. When looking at the firewall on the passenger's side you will see the drain's rubber gasket hanging down. Make sure that the drain is clear of any debris. While you are in there change out your cabin air filter.
Good luck!
2008 GT/CS - {SLP Loudmouth Axle Back Exhaust- SR Strut Tower Brace - Raxiom Sequential Tail Light Kit - C&L Street CAI - Bama Tune - FRPP Lowering Springs - FRPP Rear Sway Bar - FRPP Struts & Shocks - BMR TCA032 LCAs}
jellyroll is offline   Reply With Quote
Old 03-25-2014, 02:03 PM   #5
MasonStacks's Avatar
I had the same problem, it's the drain plug that is plugged up with whatever debris. +1^^^
MasonStacks is offline   Reply With Quote
Old 03-26-2014, 11:32 AM   #6
Appreciate yall help!
Old 03-26-2014, 01:42 PM   #7
Terminator's Avatar
Yup it has to be the drain plug clogged under cowl
Terminator is offline   Reply With Quote
Old 03-26-2014, 04:57 PM   #8
theweekday's Avatar
Pics of what to look floor?
---------- Post added at 05:57 PM ---------- Previous post was at 05:56 PM ----------
For*
theweekday is offline   Reply With Quote
Old 03-26-2014, 06:38 PM   #9
jellyroll's Avatar
Can't copy and paste, however Google 2005 mustang cowl drain. There is a great write-up with pics on a different forum.
Old 03-27-2014, 05:36 AM   #10
Ya this is a common issue, there's a TSB for it somewhere - easy fix but very important because that water can get into your computer box and cause electrical problems from hell!
Vaiit is offline   Reply With Quote
Old 03-27-2014, 11:10 AM   #11
theweekday's Avatar
This happen to me but I dried it out with electrical cleaner
Old 03-27-2014, 11:23 AM   #12
theweekday's Avatar
Water leaking on passenger side 06gttwofast4u 2005-2010 Mustang GT 6 06-05-2013 03:43 AM
Smokes on the drivers side alot more than than the passenger side Drgula5 1979-1995 Mustang GT 4 09-15-2012 12:08 PM
Water leaking in under passenger side dash dudeitsdylan 2005-2010 V6 Mustang 15 07-06-2012 11:30 AM
I have a 2005 Mustang. It leaks rain water into the passenger footwell. How do I fix this? duran General Mustang Discussion 5 08-18-2009 07:22 PM
Leaking, standing water on both front floor boards Roz01GTRagtop New Member Introductions & Greetings 9 06-10-2006 06:56 PM
01:14 PM
