Exhaust problem - Mustang Evolution
Old 03-25-2014, 07:13 PM   #1
Depack21's Avatar
Exhaust problem
So I have the pype bomb axel back and the fitment is alittle too big and I can't tighten it enough to seal it. What can I do without havering to weld them
Depack21 is offline   Reply With Quote
Old 03-27-2014, 10:32 AM   #2
Depack21's Avatar
Someone? Anyone?
Old 03-27-2014, 08:12 PM   #3
BaSohol's Avatar
Call pypes or where you bought it from
2007 Ford Mustang GT 5spd
Old 03-27-2014, 08:16 PM   #4
Depack21's Avatar
I've had it for about 1.5 years though -.-
Old 03-27-2014, 08:46 PM   #5
BaSohol's Avatar
And your just now having a problem? It should be a slip fit and the clamp should be to tight, perhaps the clamp is bad
Old 03-28-2014, 07:21 AM   #6
Wolverine0587's Avatar
If all else fails, pop out the welder. One of y axle backs had the inlet flanged a quarter inch too far from the factory, but once we figured that out and I decided I wasn't gonna change them out anytime soon we just welded it up to seal the leak.
Wolverine0587 is offline   Reply With Quote
Old 03-28-2014, 09:33 AM   #7
Depack21's Avatar
I'm putting on an off road h and I'm not sure which axel backs I'm gunna want since the pype bombs might be too loud so I want to be able to switch them out. Is there something that I can put around the pipe so it makes it tighter? The only thing I can think of is like tin foil but that seems kind of cheap
Old 03-28-2014, 09:58 AM   #8
If you can find a thin enough walled pipe to fit over the over axle pipe and inside the flange of the axle-back that may help.
Old 03-28-2014, 01:58 PM   #9
UGAKIDD7's Avatar
Go to an exhaust shop they should have a pipe bender that has an attachment to flare the end
UGAKIDD7 is offline   Reply With Quote
Old 03-28-2014, 03:58 PM   #10
^or that.
exhaust
Exhaust Opinion/Problem explicitrock Pre-2005 V6 Mustang 8 12-06-2011 08:05 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Exhaust Problem blue-saleen Pre-2005 V6 Mustang 28 03-21-2010 02:17 PM
Exhaust leak to bigger problem? mrjones3133 Pre-2005 V6 Mustang 17 04-29-2009 08:29 AM
12:22 PM
