Bad Intake Manifold? - Mustang Evolution
Old 03-29-2014, 01:19 AM   #1
Hello people,I just joined this forum,thanks for having me.
I am having some on going trouble with my stock intake manifold.
Here is my story in short : check engine light came on,gave me the codes 171 and 174.lean on both banks,changed the mass air flow sensor 3 times,no change.
I then got some carb cleaner and looked for leaks,there was a leak on the back of the intake manifold so I took it apart and changed the gaskets.
I put everything back together,checked for any more leaks and ITS STILL LEAKING from the SAME PLACE ONLY!! What am I missing? Is the manifold bad or what??? I need help!!! Thanks.
Bluerings is offline   Reply With Quote
Old 03-29-2014, 04:12 AM   #2
maldog's Avatar
Region: Nevada
Did u look for cracks in the manifold when u had it off?
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 03-29-2014, 10:25 AM   #3
I did not look for any because at that time I thought it was just the gaskets!
I've heard that sometimes the crack can be very very small,is there a specific way for checking for cracks on the manifold??
Old 03-29-2014, 02:12 PM   #4
maldog's Avatar
Region: Nevada
Maybe some fluorescent spray dye.
Old 03-29-2014, 04:33 PM   #5
Have you guys had such a problem or heard of bad intake manifolds?? My other question is : if I take it off and take it to a shop,would they be able to determine if it's bad??
Can oil get low if I have bad intake manifold 96 mustang gts/248 a skorch85 New Member Introductions & Greetings 0 02-19-2014 08:02 PM
Boss intake manifold and the stock intake Yellow50 2011-2014 Mustang GT 43 04-26-2012 07:30 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 05:55 AM
95 Intake manifold. Calston31 Pre-2005 V6 Mustang 6 12-05-2004 06:42 AM
Intake manifold and cylinder head jwscorpio Pre-2005 V6 Mustang 4 02-27-2004 07:49 AM
06:17 PM
