Weird noise? or normal? - Mustang Evolution
Old 04-08-2014, 07:58 PM   #1
StrykerGT's Avatar
Hello everyone, so i have a 2009 GT, and this is my first manual car. When i first got it, i noticed that if im cruising in 4th or 5th gear at relatively lowish speeds, as in like 35-40 in 5th gear or 20-30 in 4th gear, having rpms somewhat low, and i give it gas, i hear like a rattling or some sort of vibration of something coming from the back or atleast under the car, i honestly cant explain it. Almost like the drive shaft is turning, but slowly and really loud, and if i do it hard, it kicks fairly hard. I figured it doesn't just cut loose and shoo the rpms up, so i think my clutch is fine. So i figured it was normal because of the lowish speeds i was driving at with low rpms. But anyways, iv been reading forums and now i wonder if this is normal or not?
Thanks!
StrykerGT is offline   Reply With Quote
Old 04-08-2014, 08:30 PM   #2
Langer1099's Avatar
Aftermarket exhaust? Or stock?
Check exhaust hangers. I wrapped mine in rubber tubing because they were rattling/banging weird noise against the frame.
2009 Mustang GT Premium; FRRP 4.10 Gears, J&M Lower Control Arms, BBK Long Tube Headers, BBK Catted X Pipe, Pypes M80 Mid Mufflers, Pypes Pype Bomb Axle Back, JLT Series 3 Cold Air Intake, Bama 93 Octane Race Tune, Black Decklid Panel, Weathertech Mats, SVE Shifter and Shorty Antenna.
Langer1099 is offline   Reply With Quote
Old 04-09-2014, 04:37 AM   #3
StrykerGT's Avatar
Aftermarket. But i dont think its the exhaust, it sounds like somthing mechanical from either the drive line or rear axel
Old 04-09-2014, 08:48 PM   #4
Aggiesrok's Avatar
Could be your CV joint on the drive shaft.
Old 04-10-2014, 08:15 AM   #5
Send a message via AIM to Borii
Or simply because he is too low of a speed for the gear. In ANY manual car, if you are in 5th at 30 MPH the car will vibrate and gradually smooth out when it reaches a more suitable speed.
In generally, you should be in a lower gear by at least 1 on each of your examploes, OP.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 04-10-2014, 01:32 PM   #6
StrykerGT's Avatar
Thanks Borii, thats what i figured it was, but i wanted to make sure just in case
Old 04-10-2014, 01:35 PM   #7
Remember, I am obviously not there to know if that is sound you are describing, just a guess based on your description.
Sold - 2001 Audi S4
Old 04-10-2014, 05:50 PM   #8
StrykerGT's Avatar
Well, im hoping thats what it is, cause its almost the same sound as if im going to stall starting off.
But thank you, i appreciate it
Old 04-10-2014, 10:27 PM   #9
Now THAT makes me even more confident hehe
Sold - 2001 Audi S4
Old 04-11-2014, 04:21 AM   #10
StrykerGT's Avatar
Thanks one again!
Weird popping noise from rear iwannagofast 1996-2004 Mustang GT 1 05-12-2009 12:10 AM
Weird noise electricstang Pre-2005 V6 Mustang 17 06-20-2006 06:29 AM
weird noise.. white 98 gt 1996-2004 Mustang GT 0 12-11-2005 05:55 PM
weird noise... project232 Pre-2005 V6 Mustang 5 04-13-2005 08:28 AM
OMG.. WEIRD.. so weird.. wiarumas The Bar 14 02-17-2005 12:45 PM
09:43 PM
