Steeda under drive problem - Mustang Evolution
Old 04-09-2014, 09:09 PM   #1
I installed steeda under drive pulleys and ever since I have my car will die sometimes when I stop and it's in neutral or when I start it it will barely rev and I have to press the gas. Help!
Dcarp_10 is offline   Reply With Quote
Old 04-09-2014, 09:48 PM   #2
BaSohol's Avatar
Try disconnecting the battery and for a few mins and see if it learns the idle again
2007 Ford Mustang GT 5spd
Old 04-10-2014, 08:17 AM   #3
Send a message via AIM to Borii
Since these pulleys under drive, you may have a poorly charging alternator or battery which is being exposed by the under driven accessory.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 04-10-2014, 11:15 AM   #4
tj@steeda's Avatar
Sounds like you may not have the crank pulley on all the way. The car will run bad if that happens.
Did you put the stock bolt back in or did you leave our 'starter' bolt in?
The pickup wheel for the crank sensor is behind the bottom pulley. If the pulley is not on all the way, the wheel wont line up with the sensor and the car will not run well.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 04-10-2014, 01:18 PM   #5
Best Regards,
TJ
Good to know!
Sold - 2001 Audi S4
Old 04-11-2014, 11:19 PM   #6
Feint Motion's Avatar
Best Regards,
TJ
great advice
Feint Motion is offline   Reply With Quote
Old 04-12-2014, 10:48 AM   #7
I fixed the problem. I just cleaned my throttle body and it runs better now than it did when I first got it!!
Old 04-12-2014, 01:51 PM   #8
Vistablue's Avatar
Can slow throttle response be caused by dirty throttle body also?
Sent from my SM-N900V using Mustang Evolution mobile app
Vistablue is offline   Reply With Quote
Old 04-12-2014, 02:16 PM   #9
Yes. Clean yours and you'll notice a difference.
Old 04-14-2014, 10:06 PM   #10
What do you all use to clean yours?
AnconaGT is offline   Reply With Quote
Old 04-15-2014, 05:37 AM   #11
I used a old rag and it got every black gunk **** out
Old 04-15-2014, 10:23 AM   #12
Vistablue's Avatar
What did you use as a spray?? Throttle body cleaner?
---------- Post added at 12:23 PM ---------- Previous post was at 12:22 PM ----------
Also did u lift the butterfly's and do the inside also
Old 04-15-2014, 12:33 PM   #13
Throttle body spray and yes lift them
Old 04-16-2014, 11:26 AM   #14
Vistablue's Avatar
Ok thanks man.
Old 04-27-2014, 05:07 PM   #15
lsufan56's Avatar
Go to O'Reilly auto parts and get CRC throttle body and air intake cleaner, it worked great. And CRC makes a whole line of engine cleaning parts! Check em out!
lsufan56 is offline   Reply With Quote
Old 04-27-2014, 05:11 PM   #16
lsufan56's Avatar
I also ran a can of sea foam through mine after I cleaned the throttle body. It made mine Run a lot smoother
Old 04-27-2014, 06:37 PM   #17
Vistablue's Avatar
Finally had time to take mine apart this evening. Took the throttle body off and cleaned it. Man was it dirty. Took awhile to clean it with throttle body cleaner.
Old 04-27-2014, 07:20 PM   #18
lsufan56's Avatar
Good deal man it should run better now.
Old 05-12-2014, 09:17 PM   #19
wessstblvdd's Avatar
Try cleaning the throttle body or check your MAF sensor ! One of my buddies just installed the same pulleys on his 05GT and he feels the difference! You should like them bro
---------- Post added at 03:17 AM ---------- Previous post was at 03:16 AM ----------
Try cleaning the throttle body or check your MAF sensor ! One of my buddies just installed the same pulleys on his 05GT and he feels the difference! You should like them bro.
wessstblvdd is offline   Reply With Quote
Old 05-13-2014, 07:20 PM   #20
tj@steeda's Avatar
Thank you for the feedback!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Under drive pulleys question mk70ss 2005-2010 Mustang GT 1 07-30-2010 10:14 PM
Just installed my under drive pulleys! SickGT 2005-2010 Mustang GT 8 07-07-2010 10:08 AM
Under Drive Pulleys 2007STANG Pre-2005 V6 Mustang 2 06-01-2009 10:09 AM
Under Drive Pully's wvstang5.0ho 1979-1995 Mustang GT 12 09-16-2008 10:51 AM
Under drive pulleys, should I or shouldn't I? microflight 1996-2004 Mustang GT 32 07-30-2007 12:31 AM
03:44 PM
