Double gasket problems on oil filter - Mustang Evolution
Old 04-14-2014, 07:22 AM   #1
CyStang's Avatar
Region: Iowa
Send a message via Skype™ to CyStang
I have an 06 Gt. I changed the oil on sat. Didn't notice the gasket from the previos oil filter was left on. Made it about a block and the oil pressure light came on. Pulled over and sure enough oil everywhere. I pulled off the filter and 2 gaskets dropped down. Now I have changed a lot of oil and I have never experienced this. Lucky I put on a new filter and filled the oil back up and she still seems to be purring like a kitten. Here are my questions. Anything I should watch out for as an indicator that something is wrong with the motor from this? 2. What I the best product for getting all the oil off everything.
CyStang is offline   Reply With Quote
Old 04-17-2014, 04:26 PM   #2
08Mustang's Avatar
You should be fine as long as you didn't keep driving with that low of oil. Same thing happened to my moms '08 escape two years ago. She's still running fine
08Mustang is offline   Reply With Quote
Old 04-17-2014, 04:29 PM   #3
CyStang's Avatar
Region: Iowa
Thank you. I figured that was the case. I have put 300 miles on it this week a a no issues.
Old 04-17-2014, 04:30 PM   #4
08Mustang's Avatar
Just be sure the gasket comes off with the filter and then lube the gasket on the new filter so it won't stick next time and you'll be set
Old 04-17-2014, 05:47 PM   #5
CyStang's Avatar
Region: Iowa
Yeah I did that. The dealer changed it last which surprises me that it happened. I guess bc it was an ac delco filter. Lol.
Old 04-17-2014, 05:49 PM   #6
08Mustang's Avatar
Oh lord yeah stay away from those haha!
Old 04-17-2014, 05:51 PM   #7
CyStang's Avatar
Region: Iowa
I bought a Wix. I am trying to decide if I should change to Royal Purple next time.
Old 04-17-2014, 05:53 PM   #8
08Mustang's Avatar
Wix makes good stuff! And absolutely not! Royal Purple is vastly overrated and their oil provides little protection. Check out any independent study and examination of various oils and RP doesn't score very high. Pennzoil ultra is the best oil on the market!
Old 04-17-2014, 05:55 PM   #9
CyStang's Avatar
Region: Iowa
Ok. I will check it out. I am running Valvoline Synthetic.
Old 04-17-2014, 06:02 PM   #10
CyStang's Avatar
Region: Iowa
Old 04-17-2014, 06:28 PM   #11
WJBertrand's Avatar
Saw this happen a number of times with spin-on filters back when I worked in a service station during my college years. The boss taught us all the clean the gasket sealing area on the block with a rag before installing the new filter. If there was a gasket left behind, you'd surely find it this way before it was too late.
The old GM canister filters were really the worst, they would leave the gasket behind every time and they'd be down in a recessed, hard to access area forcing you to pick it out of there with a sharpened awl. Kept one in the shop at all times specifically for this issue.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 10:51 AM
Oil pan gasket need replaced? DaYanks4Ev Pre-2005 V6 Mustang 7 03-15-2012 09:47 PM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 02:24 AM
cold air k&n filter PN/filter size tire Pre-2005 V6 Mustang 0 12-05-2003 05:37 PM
06:40 AM
