Factory security system going off - Mustang Evolution
Old 04-16-2014, 09:12 AM   #1
rangerbert's Avatar
I'm having issues with the factory security system. It all of a sudden started randomly started going off at 2 in the morning last night. I got my key fob out got it to shut off. Then at about 10 this morning it started randomly going off again as I was pulling back in driveway. It stopped on it's own then 2 minutes later started going off again. This has happened like 2 years ago when I first bought the car. Hasn't done it much since. Was wondering if anyone knew what the problem was and how to fix it. Any help is greatly appericated.
rangerbert is offline   Reply With Quote
Old 04-16-2014, 09:24 AM   #2
First thing I would do is unplug battery make sure wires aren't corroded etc, then move to the fuse box, check fuses. Simply things like that can fix big issues.
AnconaGT is offline   Reply With Quote
Old 04-16-2014, 10:00 AM   #3
JimC's Avatar
Most likely issue is the underhood sensor at the passenger side strut tower. It is most exposed to elements and goes bad. About $35 for a replacement
Sent from my SM-T217S using Tapatalk
JimC is offline   Reply With Quote
Old 04-16-2014, 10:02 AM   #4
rangerbert's Avatar
I just put battery back in last week. I had it out for the winter. The terminals are clean. I'll check fuse box and fuses
Old 04-16-2014, 10:05 AM   #5
rangerbert's Avatar
Can you post pick of what the sensor looks like.
Old 05-04-2014, 06:10 PM   #6
rangerbert's Avatar
I think I have this problem solved. I talked to a mechanic about this issue. He said that since I only had 1 key that I probably needed to get another one and have it programmed. So thats what I've done. Hopefully my issue is resolved.
Old 05-04-2014, 07:44 PM   #7
JimC's Avatar
The keys probably have nothing to do with the random alarm. The car doesn't know how many you have in your possession, only how many are programmed to it. If you had the other key and leave it in a drawer in your bedroom upstairs it isn't going to have any effect upon the alarm the system. I had three keys in my possession and programmed to my 2006 and the alarm went off randomly; the number of keys you own has nothing to do with the random security alarm. It was the underhood sensor.
Did you check the underhood sensor? That is the most common cause of the random alarm problem. It is the most exposed and the first to fail.
Old 05-04-2014, 07:49 PM   #8
JimC's Avatar
I don't have a picture. But it is located between the shock tower and fuse box on the passenger side. It looks like a plunger on a tab from the fender. The hood pushes it down to close the circuit. When it goes bad, the system reads the hood as open, and sets off the alarm.
Edit:
Actually you can see it in this picture -- toward the front of the fuse box and on the tab from the fender.
Old 05-04-2014, 08:10 PM   #9
rangerbert's Avatar
Thank you for the info. I'll keep this in mind. If the alarm goes off again I'll get this sensor changed. Do you know the name of this sensor.
Old 05-04-2014, 08:31 PM   #10
JimC's Avatar
I don't recall the part name now, and tossed the box with the old sensor in it when I was cleaning the garage last month.
Probably just something like "underhood security sensor" though.
When you hit the lock button on your fob twice does the horn honk once or twice? Mine would go off once at times, and then when the alarm went off and I reset it the horn would do a double honk. That means that a sensor somewhere is showing open. Since I knew that both doors were closed, I checked the trunk and then hood, closed everything up and sometimes would get the double honk again; so I knew that some sensor was bad.
Old 05-04-2014, 09:11 PM   #11
KATO's Avatar
Have your Battery tested for it's Charging. Since you've had it out for awhile, it might not be up to par or time for a new one.
Old 05-05-2014, 07:50 AM   #12
rangerbert's Avatar
Thanks for the info. After reading your post here I went and and checked how many times my horn honked after hitting the lock button on my key fob. It was twice. I'm pretty sure it's always been twice but not 100% certain.
Old 05-05-2014, 08:04 AM   #13
Send a message via AIM to Borii
Bingo. Twice means something is open. Even if it truly isn't. Sensor for sure.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 05-05-2014, 09:09 AM   #14
rangerbert's Avatar
Old 07-27-2014, 01:07 PM   #15
rangerbert's Avatar
Ok guys I've replaced the sensor that JimC had mentioned as to why the car would randomly be going off. When I hit the lock button twice on key fob the horn honked once which means the circuit is closed. Well the car alarm is still going off randomly. This has happened the other day while at work. Then again this morning. Anybody know why this is still happening.
Old 07-27-2014, 02:52 PM   #16
JimC's Avatar
Could be the internal sensor. There is a control module in the map light
Old 07-27-2014, 06:13 PM   #17
rangerbert's Avatar
I believe I figured out the problem. This is dumb on my part. I think the problem was I was accidentally setting the alarm off myself while the keys were in my pocket. I thought I was out of signal range. I always thought I had to be closer than I was to make the alarm go off.
Old 07-27-2014, 08:42 PM   #18
I hope that was your cure for seating off the alarm. My alarm went off several times during the night and I couldnt figure what the problem was...until day light I found a moth in the back seat...Im sure it was flying around inside setting off the alarm. Got rid of the moth and the alarm never went off again.
gt.cs crazy is offline   Reply With Quote
New security system PureVenom Pictures and Videos 4 05-15-2008 04:32 PM
94-98 Factory headers VS 99-04 Factory headers Herbstang Pre-2005 V6 Mustang 2 08-08-2007 04:53 PM
Security System Advice PureVenom The Bar 8 09-24-2005 06:50 PM
9 New Security Updates in Windows XP SP2 Brent The Bar 19 02-09-2005 09:10 PM
10:43 PM
