Spark plugs help?? - Mustang Evolution
Old 04-19-2014, 11:45 AM   #1
NFloris_05's Avatar
Spark plugs help??
So I changed my spark plugs yesterday, and afterwards my car ran perfectly, better than before, my MPG went up, the car felt brand new (76,XXX miles). Today however was different, my car was shaking a lot during take off, and my check engine light came on and won't go away. I checked all the boots and plugs, they were all sealed well, and my battery was plugged in fine. Any thoughts as to what is going on? Thanks!
NFloris_05 is offline   Reply With Quote
Old 04-19-2014, 12:04 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Did you check the gap on the new spark plugs? Even plugs that say they're pre-gapped should be checked. If the CEL is on, you should be able to pull a code off your ECU that'll point you in the right direction. Do you have a tuner or OBD2 reader? If not, AutoZone or any of those other auto parts store should be able to read the code for you.
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 04-19-2014, 12:39 PM   #3
NFloris_05's Avatar
I did the system check through the ECU and they all check out fine. I'm trying to get a hold of a buddy of mine who might have a tuner, but I don't have any of those tools myself.
Old 04-19-2014, 12:41 PM   #4
NFloris_05's Avatar
Update: I had to move my car out of a driveway, and while doing so my car smelled like straight up gasoline, which it's never smelt like before. There's no leaks and nothing is wet, but the inside of my car smells like gasoline, and standing behind my car all it smells like is gasoline.
Old 04-20-2014, 07:15 AM   #5
G3ARH3AD's Avatar
Did u tighten the plugs really tight if not then they are skiping due to the plug or 1 broke while installing, if u bought motor craft plugs they can not b gapped for a 3v but just remove them n if they look black then they were not tight enough
G3ARH3AD is offline   Reply With Quote
Old 04-21-2014, 07:40 PM   #6
maldog's Avatar
Region: Nevada
Did u remove your fuel rail for some reason? Even if you didn't you may have been leaning on one of your fuel rails and damaged an o ring. When you have your engine running check for any fuel spraying from one of the injectors. Good luck!
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 04-30-2014, 01:53 AM   #7
NFloris_05's Avatar
The tuner said plugs 6 and 8 weren't tight enough, so I tightened them both and double checked the other ones and they were all tightened down well. Fixed the problem for about a day, then the problems arose again.
Old 04-30-2014, 01:55 AM   #8
NFloris_05's Avatar
All injectors except one were fine, I replaced the bad injector, but the car still runs like crap. The new injector helped a bit, but the car still doesn't run like it should.
Old 04-30-2014, 02:24 AM   #9
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Hmm I know it may be a long shot, but have you changed your fuel filter? I believe 60K is the recommended mileage to change it.
Old 04-30-2014, 02:25 AM   #10
NFloris_05's Avatar
Yeah, I changed the fuel filter the first day the problems started. It fixed the problem for about a day, then the problems arose again.
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 08:42 AM
No spark in the spark plugs 94GTpony 1979-1995 Mustang GT 7 10-30-2012 01:20 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
Need help with spark plugs and wires! 1sweet6 Pre-2005 V6 Mustang 21 02-06-2006 12:04 AM
07:03 PM
