Springs and cambers - Mustang Evolution
Old 04-29-2014, 01:50 AM   #1
Aspeedybird's Avatar
Springs and cambers
I posted a similar post in another topic on here on accident so I apologize if you see this twice. Anyway, I just ordered h&m lowering springs and camber plates, but I was curious if this is something I could do on my own? I know I'd have to rent a spring compressor but that's all I know. Never done suspension work before and I definitely haven't ever dealt with aligning or clambering. Should I just take it to a mechanic or are there tips to doing it myself?
Aspeedybird is offline   Reply With Quote
Old 04-29-2014, 02:18 AM   #2
Aggiesrok's Avatar
Depending on your mechanical ability and tools, you should be able to do it. Lots if people change them, but you will have to get an alignment afterwards for sure. Also depending on how low, you may need some other components to keep the geometry correct.
Old 04-29-2014, 02:38 AM   #3
The drop is supposed to be just under 2". I think it's like 1.8" in the back and 1.6" in the front, but not sure off the top of my head. They are h&r springs, and a j&m caster camber plates. If I just put on the springs and plates, would driving to a shop be an issue for getting it aligned? I'd imagine that control arms and sway bars would be necessary eventually too
Old 04-29-2014, 07:05 AM   #4
Aggiesrok's Avatar
With that much of a drop, you'll need an adjustable panhard bar, to adjust the axle after the drop, it will be off center. Also in the rear - upper control arm and lower control arms will be good. Sway bars should be ok.
Old 04-29-2014, 02:49 PM   #5
Alright I ordered the panhard too but I might wait on the control arms only because of other financial obligations!
Old 04-29-2014, 03:33 PM   #6
Doe_Rae_mi's Avatar
I Installed my lowering springs myself when I was 17. It's very easy. Also u do not need a spring compressor. Yes it will be ok that u drive it unaligned. I drove mine without being aligned for months
Old 04-29-2014, 03:57 PM   #7
2 Stangz's Avatar
Region: Nevada
Uh so did this guy and he had $1,000's of repairs 5 months later w/o an alignment/proper precautions
eibach lowering spring problem
Old 04-29-2014, 04:02 PM   #8
I was planning on only driving it to a shop maybe 30 minutes away afterwards to get it aligned. I was thinking more like that, not long term avoiding alignment
Old 04-29-2014, 04:21 PM   #9
2 Stangz's Avatar
Region: Nevada
Oh for sure, I plan to do the same when I mod my suspension. I was just talking to that specific user.
Old 04-29-2014, 04:36 PM   #10
Doe_Rae_mi's Avatar
Well I didn't. Guess he was having a bad day
Springs and cambers Aspeedybird General Mustang Discussion 3 05-01-2014 09:45 AM
Cambers and springs Aspeedybird 2011-2014 Mustang GT 1 04-29-2014 01:52 AM
Lowering springs or factory springs fordracing63857 1979-1995 Mustang GT 3 06-27-2012 08:42 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
06:59 PM
